OFFICIAL: Track videos thread [MERGED]
#301
In jefferson's case that's a road with mailboxes, may as well call it a tarmac rally stage lol. But on some of the others at least they have 50+ feet of grass before the tires/trees and not a crete wall. But at Dom it seems like there are inches and a wall so I'm wondering wth they were thinking.
#303
On the plus side, I thought Dominion was fun to drive, in a similar way to the Shenandoah Circuit (which is also full of walls). I wasn't too worried about spinning into a wall, but there is very little margin for error if your brakes go away or you encounter fluid on the track, etc.
#305
i pumped up to TT2 this past weekend because there wasn't enough people in TT3. took out about 150 lbs of ballast and put in my kill mode map, which is about 370 whp dyno jet (stock long block and stock turbo on e85). ran my fastest time to date at Summit Point, 1:16.8. my TT3 record is 1:18.2
#306
#309
Found my answer, but is rated on OE wheel/tire size.
http://www.jackstransmissions.com/pa...on-gear-ratios
The following speeds are based on an OEM tire diameter of 25.5
JDM 5th 152mph @ 7500 RPM
Per a quick search I guess thats about right for my current wheel/tire combo.
275/35R18 = 25.6x10.8R18
#312
