RaceFab wet sump pan
Old Jun 15, 2016, 12:23 PM
  #241
honda-guy's Avatar
Originally Posted by kyoo
no risk to contact crank?
always make sure crank doesnt hit scraper when installing, since not all crank casting are the same. if you have stroker crank, then you have to trim the scraper.
Old Jun 15, 2016, 01:30 PM
  #242
kyoo's Avatar
Originally Posted by NJ9MR
^ If you have a 'Stroker, you might have to trim the 'scraper a little.
stock motor & internals so I'm good there
Old Jun 16, 2016, 12:46 PM
  #243
kyoo's Avatar
thanks for the input. stock crank/internals, and I believe buschur's scraper is designed for that. just hangs there then bolted on? and I'm assuming can't/won't move?
Old Jun 16, 2016, 02:46 PM
  #244
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
You already have a stock crank "scraper" baffle thing in there. You ubolt that, put the new piece on, make sure it clears (spin the motor by hand), if it rubs, bend it out of the way (it shouldn't rub) and your're done. It's pretty straight forward.
Old Jun 16, 2016, 02:55 PM
  #245
kyoo's Avatar
I guess I'm trying to gauge how "reliable" a crank scraper is.. if it can be bent, it can go the other way too?
Old Jun 16, 2016, 02:59 PM
  #246
heel2toe's Avatar
Lol I think you officially take the cake for over analyzing things more than me, haha! bend it out of the way if need be (which most likely wont be needed for you anyway!) and forget about it. Its not going to bend itself the other way unless you bend it the other way or something hits your oil pan in which case your engine is prob toast crank scraper or no crank scraper.
Old Jun 16, 2016, 03:00 PM
  #247
What is going to hit it in order for it to bend? You have much bigger problems then a bent crank scraper if something reaches through your oil pan and bends it.
Old Jun 16, 2016, 03:04 PM
  #248
heel2toe's Avatar
^Yes, exactly. He is just special
Old Jun 17, 2016, 06:32 AM
  #249
kyoo's Avatar
lolol. just sounded as if it were relatively easy to bend - if so, 280hp of crank spinning thick oil sounded like it could too? IDK! fine I won't worry lol
Old Jun 17, 2016, 06:43 AM
  #250
It's not that easy to bend. It will require a pry bar, or a least a decent screwdriver to do so.
Old Jun 17, 2016, 09:34 AM
  #251
heel2toe's Avatar
Lol I'm just giving you a hard time; you know I aint got nothing but love for you you'll be fine bud as stated prior bolt it on 1/2" breaker bar on the crank turn the rotate the engine make sure nothing hits and bolt the pan back on. Well, of course scrape off the old RTV throw on a new bead of sealant and button her up!
Old Jun 17, 2016, 11:54 AM
  #252
kyoo's Avatar
will do fellas
Old Oct 22, 2016, 08:16 AM
  #253
Grimgrak's Avatar
Got mine driving agan notice that CEL dash light comes on under very light braking, like rolling up to a speed bump. But under hard braking it's fine. Still dont have my logger working yet so can't tell aside from the dash lights.
Old Oct 22, 2016, 10:42 PM
  #254
kaj
kaj's Avatar
An oil pan is causing a CEL? WTF?? What's the code?
Old Oct 23, 2016, 01:28 PM
  #255
mrfred's Avatar
Yeah that makes no sense.
Quick Reply: RaceFab wet sump pan
