RaceFab wet sump pan
Looks like it may not clear certain O2 dumps, especially the MAP one.
How long does it typically take for them to build one and ship it over?
Good to have more alternatives for pans...
I use to run with the OEM modified by Buschur and now I have the AMS Moroso pan... Been using this one for a while now...
Anybody that has installed a AMS pan, has notice any filling of the catch cans after the install???
I'm not at all saying this design doesn't look superior, but I want to clarify that the AMS pan controls oil under acceleration and braking. Your description makes it sound like it only does acceleration.
I may have read over it, but do you know how much capacity this pan adds?
Thanks for taking such detailed pics. I'm starting to like this pan even if its overkill for me. Is the turbo drain inlet at the same level as the ams/stock one or did they raise it up a bit? My car has an ams pan and a FP bb turbo and gets a little angry if the oil is run at or above the full mark. A tiny bit low and all is well.
How was the fit on the block? Did you use Hondabond?
It's an oem pan at heart so the block fit and drain location are stock which is my main driver for it. However in bolting on the parts tonight the wrapped downpipe and the 45deg AN fitting touch, not by much but enough that i'd likely get a lower downpipe later to keep the pressure off. Threebond is what I used and recommend. It's really the same thing as honda/mitsu/subu bond but cheaper since no markup. In filling tonight also it shows about .5 quarts high with 7 quarts in the pan, but this is likely due to my filter and cooler/lines being empty and the car being at a slight angle. I allowed the bond to dry for 24 hours before adding oil.
i didn't have datalog for oil pressure, i just go by the in car video of the oil pressure gauge. NJMP Lightning track have a high speed 180* right turn that kills tires and drop oil pressure for long duration. it's a good spot for me to compare oil pressure drop.
watch this video in high res, and look at the middle gauge, that's the oil pressure gauge. with stock oil pan.
any Evo with stock oiling system and sticky rcomp tires will see the same thing, if they have an oil pressure gauge in their car.
been tracking the car like that for 5 year since i bought the car
here's video of the car from 2014 with 2.3 and ams (morroso) pan, and no oil spirters. i always over filled oil at the track about 1/8" over the max mark. you can see the oil pressure gauge, the pressure drop quicker and a lot more than the vid with stock oil pan.
