Help with alignment.
Old Dec 10, 2015 | 09:28 PM
PonoPride's Avatar
Hey guys I'm looking for some good baseline alignment specs for auto cross. To give you some background info I have a 2008 evo x gsr, running rpf1 18x10.5 +15 wrapped with 295/30 AD08R's, works front and rear sway bars, whiteline endlinks and rca kit and I'm installing HKS GT coilovers. I run in the SM class and i also daily drive this car. Thank you so much in advance and aloha.
Old Dec 11, 2015 | 09:20 AM
RJones's Avatar
What spring rates are you running? Rear diff? -3.5/-2.0 would probably be a good start on street tires. Tire wear won't be bad with 0 toe all around.
Old Dec 14, 2015 | 08:32 AM
PonoPride's Avatar
they are 8kg front 5kg rear. stock rear diff.
Old Dec 14, 2015 | 09:59 AM
LetsGetThisDone's Avatar
You're going to want to make some big changes to spring rate. At least bump the rears up to 8k, or go to 10k/10k.
dek0026
May 15, 2008 03:31 AM
DjDoubt
May 23, 2004 11:39 AM
a904dam
Feb 18, 2004 06:10 AM
johnr265
Jun 5, 2003 06:14 AM
Dem1K
Lancer Troubleshooting
Jul 21, 2002 12:44 PM
