Anyone want some Aero work by Andrew Brilliant?
#31
https://www.instagram.com/jacob_rogers/
Shooting for a spring 2017 completion date :-)
#32
Since you paid for the service and have the rights to create, does that mean you have the rights to recreate? Wondering if you can recoup some of your money working with others to share the info under perhaps an NDA. Would probably be selective in who you worked with though so secrets are just leaked.
#33
I'm not saying a similar looking design won't work at all on another car. It will still make some fraction of the possible DF as a custom tweaked design.
#34
im jealous of the time you got with Andrew - i can only imagine the wealth of knowledge he has.
ive heard this stance before and while some of the things you mention make sense to me (bumper) in terms of large scale changes others dont (control arms). did he show you examples in the model of a control arm change?
Did you guys laser scan the bottom of the car?
Would you mind sharing some of your plans for the rear radiator setup? we're been researching that on ours as well.
But it is what he gets from the CFD that makes the huge numbers that someone just can't copy. Different bumper, control arms, ride height, wheel offset, tire size -- what works on my car would make much less DF on a different car. All the angles and locations and volumes need to be exactly right.
#36
You would need the gnarliest of gnarly fans to make that work, and you would need a bigger radiator than what is up front. I also wouldn't want it past the rear axle.
#37
Not past the rear axel yes, but the rest no so much. Professional Awesome has such a setup with a pretty standard cooler and 2 11-13" looking fans which are temp controlled. Also if you look at their pics they "induct" from the rear doors with particular angles and such. Awesome, yes, but only really necessary if you're going after that level of build$ and the advantages outweigh the cost/disadvantages.
#38
#39
A few autoXers have rear mounted radiators so I know its doable. One guy in a Subaru (Greg M.) has a fairly large radiator where the spare tire well is and just pops the trunk between runs (or so it appears). Another Evo guy in FP (Mike B.) has his relocated but I haven't seen his setup.
Seems like you'd really want some sort of ducting in and out to make it work properly. I'd also want it to work on track since I do run those periodically. Will be interesting to see what comes out of Evolutionary's build. Not from an aero standpoint, but from an airflow standpoint.
#42
What would be the point in the rear mounted radiator? Makes sense in cars that could see contact but not sure I see the advantage otherwise.
I thought a lot about it in an effort to move weight to the back of the car but I ultimately came to the conclusion that the cons that seemed to make it less than ideal:
More weight overall with the added lines and coolant.
More difficult to get air (seems like from an aero perspective, you'd want to pull air off the top or sides of the car, not the bottom and then use that air to help fill the wake?)
More likely to fail (more components)
Much more complex to keep air out of the system (two high points in the system now)
Don't get me wrong, interested in seeing what you come up with and love the idea just for being different.
#43
^Yes, Yes, and agreed. The bottom line is there is an Aero advantage to be had with said combination. Those that have done it, however, haven't disclosed said difference or advantage other then shared theory. So I guess if you gain 50 lbs, but gain 500lbs in downforce or less CF drag, 1+1 does equal 3 .
#44
The aluminum lines running to back of the car wouldn't weight much at all. Weight would not be a deciding factor in the rear rad. Moving weight to the rear of the car, and off the front would be.
#45
We did scan the bottom of the car.
For T/A use, I am planning on exhausting it out the rear of the trunk lid. It will be open on the front side, and ducted on the rear of the radiator to the trunk lid, which will be cut and mesh installed. We think we will be able to get enough airflow with the cabin having some pressure, and behind the trunk having a low pressure zone. We'll see. If it doesn't get enough flow, we have a great idea worked out to get the air we need without hanging huge ducts out into the sides of the vehicle causing drag.
My purpose for the rear rad is solely to get as much weight off the front of the car as possible to help it turn. I'd gladly trade 60 pound in the back if I can lose 40 pounds in the front. . .
