Evo X front brake swap for Evo 8/9
#436
The thing about AX that most track guys don't get is that we have ZERO airflow after the heat is made. So it just sits and gets everything else hot. So we don't have the same peak rotor glowing temps, but once we're hot we aren't cooling down. Its generally more of an issue on coolant but with braking we do need a pretty good pad that can handle the heat without falling off.
#437
#438
i was responding to phaz's comment just above mine
but yea, as I said, street, no difference, autox, (likely) no difference, track yes. no use on a street car
#440
I have a set of X calipers on the way now. Will be ordering RB stainless pistons and 2pc rotors shortly. 2pc rotors will be for track use, and I'll be getting some cheap centric premium blanks for street use.
#442
Originally Posted by kyoo
sweet! thought u were gonna get something else?
#444
Ok just did this upgrade also. Braking feels about the same as before but the look factor alone is enough for me to do it again If I had to. Have 18x9.5 nto3s and the evo 8 brembo and rotor always seemed a bit small. Space is filled up with the bigger rotor and I can def use a thinner spacer than the 10mm I currently an using.
well worth it imho.
well worth it imho.
#445
well worth it imho.
well worth it imho.
#446
Purely street use. Possibly why I haven't noticed a difference as yet. It does feel great, somewhat similar to the stock brembo setup I guess. But under my 18s the look is superb. I'm assuming if I do push the car coupled with some hard braking I may notice the difference.
