18 X 9.5 Track Wheels
I had five 18X9.5 +25 Konig Miligrams but bent two of them and I have been unable to find any for sale. So I'm looking to buy a new set of wheels for tracking. The Konigs fit perfectly and I like to get as close to the same offset and I would like to avoid spacers. I would really like to find something under $300/wheel. Any suggestions?
If not, Enkei NT03+M 18x10.5 +30. No spacers needed if you aren't running crazy wide tires.
I will also check into the Enkei's. Is a front spacer required for a +27, is it that close (25 works find)? Also, 10.5 are intriguing and could have a future someday.
I just got a set of Weds tc105n's 18x9.5 in the mail today. So light and super strong. We used the hell out of our 18x10.5" last season and they're straight as an arrow.
struts are a different story depending on tire and strut configuration.
with 275/35/18 NT01 and ohlins at not super low configuration:
No spacer:
5mm spacer:
12mm spacer:
Also, Gram Lights 57DR 18x9.5 come in +22
Another vote for 57DRs. I just put an order for Volk CE28SLs 18x9.5 +22, but was also looking at Advan RGD2 in the same size. Can't go wrong with Rays or Advans.
I don't know why but this image turned me on:
Since I'm now looking at the Hypergrams as well, Konig lists the 18x10.5 +25 as 1 lb less than the 18x9.5 +25. However given Razorlabs pics with Ohlins, it looks like at least a 3 mm spacer (and therefore extended studs) would be needed to give some breathing room with 275/35-18 NT01s (or Maxxis RC-1s?) on the inside. So is the weight savings is essentially cancelled out between the 9.5 vs 10.5? The pro of going with the 10.5 is better fitment with a variety of 275/35 tires, correct?
While it was mentioned that 5 mm spacer could be used with stock studs, since (my) primary use is at the track, is it worth the risk?
