Car is 3 wheeling, Stiffer swaybar or up spring rates?
#48
Heh, Well now that sounds just about right. I do know some other fast AX people that are also much higher than they use to be and got faster for it. I know some subcribe to the idea of CG first, geometry later, but Evos do different things front and rear that it densest really work that well. Roll axis with one above ground and one way below, now thats a funky setup
#50
so where do u recommend measuring from?
Ive been recently measuring from the back of the wheel arch where that pinch weld is. or front of the wheel arch for the back. due to having a flat bottom i cant get to the jack points where people normally use.
Is it maybe better to measure directly from the bottom of the ball joint?
#52
If you think you're going to do this you might want to do it sooner rather than later.. it will probably change a lot about how the car handles and you may have to reconsider a lot of things.
I dunno about the more expensive Tein stuff, but Tein is not typically known for having lots of travel and absorbing bumps well
Originally Posted by bee-radd
One thing i would really like to do is set the ride height up. im wondering if maybe the ride height is too high and the suspension isnt getting much travel. i tried to keep the A arms level but i might drop the whole car down like 20mm and see how that feels also. probably not for this track as pukekohe is stupidly bumpy and the car already bottoms out down the front straight.
#53
#54
Ground to fender, on track racing Evos, front and rear, will measure about 24.5".
On dual purpose about 25.5" front 25.25" rear perhaps.
I regretfully forgot ground to pinch weld, but dare to suggest that 25.5" front (and 25.25" rear) results in about 6.25" front and 6.5" rear ground to pinch weld distance.
FYI: RS rear LSD will induce more push, understeer. AYC is torque vectoring, so driving out understeer. Change in behaviuor with RS will be somewhat "negative", but maybe more "consistent". Maybe: in my experience AYC on car with settled chassis (properly set on stiffer coilovers etc) works super predictably and in the magic-way it was designed to, only on stock suspension AYC may surprise the "uninitiated driver". Nobody says Evo X is unpredictable at the edge, nobody: yet it has AYC! So its one of those "folk-tales" from the past, just like upgrading Evo Rod bolts..yet rod bolts never break but rods do!! And often from poor tuning, what is even worse.
#55
As a bonus, I don't have to worry about parking lots because the lip clears curbs
#56
I can confirm, if your control arms are level in the front you are pretty much at stock ride height. My car was recently on stock suspension and I took a look at the front control arm angle and I noticed that it was parrallel to the ground already. Unless you have done the Whiteline RCK ball joint then you can go a bit lower and still have parallel arms.
Dallas is right, the front can do some wonky stuff with ride height on the Evo. But the general rule is lowering the front, lowers the front CG and reduces lateral load transfer. This increases grip. But it increases front body roll due to the increase in roll couple, which can negatively affect camber as you are on a crappy part of the camber curve due to the angle of the control arm and that can reduce grip. Then there is the wheel rate due to the springs, motion ratio and the sway bars. It's a complex multi matrix problem to solve. If you go too low you end up losing grip but there is a sweet spot and that depends on your setup.
Also the way I like to measure ride height is from the wheel center to the fender lip, that way it isn't affected by the diameter of the wheels.
Have fun.
Have fun.
#59
Boostfiend
15
Apr 12, 2011 07:54 PM
DaWorstPlaya
Aug 20, 2006 01:13 PM
andyng
10
Feb 13, 2004 07:40 PM
