2019 D-Street discussions
Old Nov 2, 2018 | 06:03 AM
  #31
Prime12's Avatar
You and me both. I drove Elias's RS at WDCR last Sunday and still feel the same way. I feel the only area where the RS would have a clear advantage is coming out of slow (and by that I mean local Miata club 15 mph pin turn slow) corners where the X is completely off boost and just miserable. But how many of those corners are there on national level courses?
Old Nov 2, 2018 | 06:06 AM
  #32
MrAWD's Avatar
That might be an issue for 5-speed EVOs...auto trainy ones have no issue with those. As a matter of facts, those are the segments that auto trainy EVO does better than any other car I have ever driven.
Old Nov 5, 2018 | 12:10 PM
  #33
aklucsarits's Avatar
H*ck yeah! I'm the original owner of a still-stock Evo9 that's about to come out of AutoX retirement. It's already got some MR Bilsteins and a rear bar. It just needs some new modern tires for 2019. Last season I autoxed the Evo, (4-5 years ago??) it was on 255 width Rivals on the stock legal 8" wide wheels, which fit OK and seemed to work well at the time.
Old Nov 5, 2018 | 12:11 PM
  #34
Prime12's Avatar
Good to see you here! I know who you are...
Old Nov 5, 2018 | 12:34 PM
  #35
^ Well then you know I'm a glutton for punishment because I've been driving a Mini buried in DS the last few years. The Evo should be a little faster...
Old Nov 5, 2018 | 12:43 PM
  #36
Prime12's Avatar
Some friendly CT9A vs CZ4A action next yr?
Either way, we shall crush those pesky Focus RS's
Old Nov 5, 2018 | 12:49 PM
  #37
kyoo's Avatar
what would be the must haves for the 8/9/10 chassis for DS? i've no idea for the 10's but i'm thinking the 8/9's will NEED:
- restacked rear diff
- big *** rear sway bar
- lightweight catback
- super stiff custom valved shocks, I'm thinking with less travel & stiffer bumpstops to get a stiffer effective rate
- the usual, good pads, good tires, prob 255s stuffed on some light 17x8s. tc105x is probably the way to go there.
the suspension/shock set up is gonna be crucial to countering the soft springs on the 8/9s.
Old Nov 5, 2018 | 12:59 PM
  #38
Dallas J's Avatar
Veteran: Army
From back in my wow days, this starting to sounds like a lvl19 "twink" pvp. Lol. I'll just never understand
Old Nov 5, 2018 | 01:06 PM
  #39
Prime12's Avatar
X's Achilles Heel is also the stock soft springs.
I trophied at Pittsburgh Match Tour (and would have at Finger Lakes but for a stupid dnf that was 100% my fault) with just a Whiteline front sway bar and 275 stones on OEM wheels.
I feel I could have been a trophy fodder at Lincoln (just barely) with the current setup had I run mine.
Danny seems to think proper shocks would make the car a lot quicker, so maybe include the shocks to the 'must haves' if the goal is to trophy comfortably at national levels?
Old Nov 5, 2018 | 01:09 PM
  #40
MrAWD's Avatar
This looks similar for X as well:
  • nothing to do with rear end - AYC
  • big *** front bar - lot more weight at the front requires as much stiffness as possible, which makes better balance overall
  • light way cat back - possibly muffler delete - same as 8/9s
  • lots of rebound in shocks as well - you mentioned stiffer bump stops and shorter travel, but it might be illegal as far as I know - travel is +- 1" and bump stops could be enlarged to fit bigger shaft, but not stiffness of length of it.
  • X has bigger rims (8.5" vs. 8"), so larger tires could be used - I believe 275s are the way to go for best possible heat management
  • as of pads, X comes with bigger rotors, so even factory ones (aka. DS2500s) are pretty good. I have tried stronger ones and they were too much for street tires - maybe I went too far!
  • there is also an option to go with two different transmissions and my vote goes for auto one, but more testing is required here.
  #41
kyoo's Avatar
yea i think stiff shocks with less travel + bumpstops are gonna be a must have for any street car with soft springs
Old Nov 5, 2018 | 01:11 PM
  #42
MrAWD's Avatar
I thought you are here for the jacket...
Old Nov 5, 2018 | 07:23 PM
  #43
Butt Dyno's Avatar
From: Why do they always call the Evo the Dark Side?
Were you at the Dover tour in 2013? I remember seeing a street-class Evo then and thinking "holy cow, one of them exists"
Old Nov 6, 2018 | 05:23 AM
  #44
Yes! I won my first and only national-level trophy in the short-lived RTA (Street Tire, AWD, Stock) class at that event. First place in a class of... two.
Old Nov 6, 2018 | 07:52 AM
  #45
Balrok's Avatar
If you have to ask, u just don't know
