If you are really anti Walbro, and you made sure you have genuine walbro and still hated it, then get something like an aeromotive pump.
The one thing I will say about the wally 255, is that they are very sensitive to being run dry or low on fuel and over heating. Once you do that, they can whine and fail. It's probably good practice to not run around with an almost empty tank in an Evo, but that's none of my business. :P
Its sitting in the slave cylinder. I pulled mine back when I put in a SS line. It might help save your drivetrain from the shock if you were to accidentally side step it. Personally, I wanted mine out but if you have codrivers who are used to RWD platform, might be wise to keep it in there.
Also, my clutch pill is removed. Knowing what I know now, I don't think removing it has any real benefit. Leaving it in makes it easier to modulate the clutch though.
i didnt realize the walbro was literally the only fuel pump that was reliable and worked for our cars.
also not sure if relevant - will be on stock engine/turbo, 24psi max
