Old Dec 15, 2020 | 10:31 AM
  #2626
kaj's Avatar
kaj
While that is a good idea, you'll have the studs/anchors sticking out of the ground everywhere you want to be able to put the lift, so keep that in mind.
If you can vault the ceilings and get a full height lift, I would go that route.
The anchors are slightly counter sunk. Nothing in the way, which makes it really nice.
Originally Posted by deeman101
If you're going to pour a concrete pad anyways for whatever reason, might as well pour it thicker. Otherwise yea just cut 2ft squares in the existing pad and pour thicker concrete what the jack is going. I had mine poured while my house was being built and got a 6inch 8000psi concrete pad poured and it cost me an extra $1500 over the normal pad thickness..... pretty cheap overall.
Not bad, considering I paid $800 for two, 24x24x6 pads, installed with rebar.
Old Dec 15, 2020 | 03:54 PM
  #2627
Construct's Avatar
Do you have a photo? This is exactly what I was considering.
With concrete, getting all of the trucks, workers, and materials on site is half the battle.
Old Dec 15, 2020 | 04:19 PM
  #2628
kaj's Avatar
kaj
I'll look. I should, somewhere. I actually haven't taken the lift down since putting it up. ...but I know I took pictures after gluing the anchors in.
Old Dec 16, 2020 | 07:46 AM
  #2629
kyoo's Avatar
def something i may consider. the quickjack is nice and has been very useful for maintenance, but it still doesn't leave me with a ton of space if I want to do anything more significant
Old Dec 17, 2020 | 01:44 PM
  #2630
Lumpy Sticks's Avatar
5 Year Member
This weekend is finals for the series I race in. I was bummed that I didnt get in since tickets sold out in 10 seconds (no joke). But I got a call today and they squeaked me in! Now I have 2 short nights to prep the Evo and hope for the best. Super excited though.
Old Dec 17, 2020 | 06:01 PM
  #2631
Balrok's Avatar
Originally Posted by Dallas J
ECU Payment made! Since the winter sale also means a little wait for it, I'll have some time to knock out other projects. Of which I have A LOT
Ditto! M150 + level 2 logging. Went for the Universal crank trigger since that'll last through any engine design but still lets you use the oem. I'll likely keep OEM trigger for 2021 since this thing won't get here till late Jan as you said. But they have no clue on the ACD part in reality - so I'm gonna rely heavily on you to start buddy
If it wasn't for the price tag I'd be a tad more excited lol. Between this and a sequential...... I'll take this 100x.
Old Dec 17, 2020 | 06:19 PM
  #2632
Dallas J's Avatar
Veteran: Army
Sounds like our setups are going to be pretty much the same there then.
I'll probably be working a lot to get something working well for ACD stuff. Might even go back and forth between stock ACD ECU and the Motec to get an idea of what its doing and when a bit more (Now with more logging prowess)
Old Dec 17, 2020 | 06:34 PM
  #2633
kyoo's Avatar
good luck!
Old Dec 17, 2020 | 06:37 PM
  #2634
Balrok's Avatar
So what are you using for the "rest". PDM, display, cam, sensors, blah blah blah. I may likely sell the AiM stuff if any of you guys are interested.
Old Dec 17, 2020 | 06:58 PM
  #2635
Dallas J's Avatar
Veteran: Army
No PDM for me, just going to do it drop in style with OEM to get going for now. I do have RaceCapture also to collect other datas like Tire Carcass temps (coming soon...). So things not ECU related I will run to that and the rest will go to M150. Then I will probably work on figuring out how to get data from M150 to RaceCapture for adding to my mid course logs to really understand whats happening during a run.
Old Dec 18, 2020 | 09:52 AM
  #2636
5 Year Member
Originally Posted by kyoo
good luck!
Thanks!
Old Dec 20, 2020 | 12:53 PM
  #2637
211Ratsbud's Avatar
Very interested to see what particular projects you get on to and what you do with that Motec!
Old Dec 20, 2020 | 10:37 PM
  #2638
deeman101's Avatar
What do you guys think of these to hold on a splitter? https://www.quik-latch.com/black-ano...uik-latch.html
Basically low profile hood latch pins. Claimed to hold 150lbs each and it won't disturb the airflow too much. I like that the height is adjustable too. I was thinking putting in some rivnuts into the rad support/crossmember and thread the rods into it.
Old Dec 20, 2020 | 11:53 PM
  #2639
5 Year Member
My tires were done after the first session today but apparently thats fine.
Old Dec 21, 2020 | 06:13 AM
  #2640
Balrok's Avatar
For me the amount of material sticking up on the other side interfered on first glance so I passed.
Nice win and excuse for winning slow
