someone recently told me reusing wheel bearings for the new ssb uprights would be like putting used pistons into a new engine
@Balrok
i can still keep the used one as a spare backup, not exactly like i was gonna toss it. maybe eventually swap the core with something nice.
it's a very much while i'm in there kind of thing
on some really good news, a local car buddy is gonna help me install all this stuff next weekend
if you get the assembled ones, it comes with the flange and/or OE studs. I personally cant use OE length studs with my various wheels so I immediately install arp studs. the old ones you just replaced because new uprights can be your backup. People normally do self tech inspection a few days before an event and a fully assembled hub could come in handy
fwiw, i asked proracing and they sell 4 corners (fronts with full hub assembly, rears just the cartridge to press the hub into) for $2k. A little steep for me though.
I have genuine mitsubishi hubs as my back up too
a buddy of mine is gonna help me do all this work next weekend (thank god) so we're gonna try to knock it all out. haven't made a final decision yet on front hub, but it'll be:
- strut tower brace
- ssb upright + wheel bearing/hub assembly
- ap racing 8350
- (possibly) uicp
- (possibly) air intake pipe
with a few other things lined up for march. little by little trying to shift the weight balance on the car
- strut tower brace
- ap racing 8350
- (possibly) uicp
Make sure to use anti-seize on most everything threaded. A rat-a-tat helps speed things along greatly. Also be sure to use WOOD to tap the hubs in/out. Not the metal part of the hammer. SSB's are a perfect fit which means lining it up make take a couple tries. Some anti-sieze on the outside on the mating surface (i mean very little) helps. You may kick yourself for not getting his control arms
Buuut, fear not replacing control arms is 3 bolts if you do it after. What else...oh...be ready for WTF levels of grip, braking, and overall joy. THEN you'll be asking yourself why the REARS are 2x better performance then doing the fronts
. And then we'll likely get another 300 questions just so you can keep EvoM post activity up haha.
. And then we'll likely get another 300 questions just so you can keep EvoM post activity up haha.rear uprights are next on the list, but probably a 2023 thing for me.
