Old Jan 21, 2022 | 10:32 AM
  #4066
Dallas J's Avatar
Veteran: Army
Also, dont disassemble the ebrake. It comes right out with the 4 bearing bolts and 1 upper bolt.
Old Jan 21, 2022 | 10:39 AM
  #4067
ViciousLSD's Avatar
ah thats right. 17mm i think for the heatshield. pliers to get some slack from ebrake cable (no need but just saying)
Old Jan 21, 2022 | 11:25 AM
  #4068
Ayoustin's Avatar
Originally Posted by kyoo
how much labor do you think a shop would charge for doing the rear uprights including assembling new rear hubs..?
Way more than what it'd cost to buy the tools and do it yourself. It's not a complicated job, just need to take your time and get everything torqued.
Old Jan 21, 2022 | 12:40 PM
  #4069
ViciousLSD's Avatar
you guys torque stuff? I just use feel/muscle memory of some sort "thats tight for that type of bolt and what it does"
Old Jan 21, 2022 | 01:48 PM
  #4070
kyoo's Avatar
would be good if there were a how to vs. do this and don't forget to do that. hopefully my buddy helping me next week will have a good sense of it.
Old Jan 21, 2022 | 02:05 PM
  #4071
kaj's Avatar
kaj
Take apart. Reverse. Google torque specs. Easy peasy. Probably how most of us learned.
Old Jan 21, 2022 | 02:10 PM
  #4072
ViciousLSD's Avatar
Here's something to give you an idea
https://www.evolutionm.net/forums/ev...placement.html
+ you just need to remove 1 bolt for ebrake/heatshield. and disconnect 3 ball joints and the control arm bolt
**the sparks is just if youre reusing your old hub/flange. (no need for a torch)
you can probably Zoom call SSB
Old Jan 21, 2022 | 03:17 PM
  #4073
kyoo's Avatar
thanks. i think i've worn out all the capital i had with ssb lmao
we also have a "fork style ball joint separator" but i think we will need to take the hub to a shop with a press to swap out the ball bearings for the rear. front, i have the whole assembly so i can just bolt it to the new spindle
Old Jan 21, 2022 | 03:32 PM
  #4074
Biggiesacks's Avatar
you guys know you can download the factory service manual for free right?
https://www.evoscan.com/vehicle-manuals
Old Jan 21, 2022 | 03:38 PM
  #4075
ViciousLSD's Avatar
dont use that fork thing. hammer tap works (youtube it) i did it on the track/venue in order to inspect my axle but tool from HF is just so easy and everywhere
Old Jan 21, 2022 | 03:57 PM
  #4076
kyoo's Avatar
https://www.youtube.com/watch?v=DRb13t9l2Oo
Amazon Amazon
this looks just like that bit. and for the rear wheel bearings, the guy lives near a shop that has a press, so i think we may be good then
paul/boosted films also did this video for the front spindles:
Old Jan 21, 2022 | 04:12 PM
  #4077
ViciousLSD's Avatar
I've seen enough rust and frozen bolts for this month. clean and lubricate every chance you get. paint is not a bad idea
Old Jan 21, 2022 | 04:18 PM
  #4078
kyoo's Avatar
yea i think that vid will be solid, on my end for the fronts won't even have to remove wheel bearing from the oem spindle (until later)
circling back to the antiseize thing, a lot of posts are saying to use antiseize, but the ssb website says to use threadlocker. these do opposite things, more or less, so which do i use?
Old Jan 21, 2022 | 04:34 PM
  #4079
ViciousLSD's Avatar
anti seize is for mating surfaces. bearing to hub, ball joint 'taper', maybe axle to hub, shaft part of a suspension bolt, anything that might get 'welded'/frozen but rust or pressure
thread locker is for tiny bolts threads that cannot be over torqued enough to stay forever. example is the SSB trailing arm, it has a pretty bolt for the ball joint.
Old Jan 21, 2022 | 08:20 PM
  #4080
Dallas J's Avatar
Veteran: Army
Yep, blue loctite on the small bolts or ones you dont intend to take off ever. Like the steering arm up front.
For popping off ball joints, I like the orilies/autozone tool the best, and its free to rent. Its not intended to fully remove things but put load on the taper so you can hit the housing and get it to separate.
https://www.oreillyauto.com/detail/c...n1/67008?pos=1
