So there was a broken vacuum port for the fuel pressure regulator and RS suspects that is what caused it. Kind of a freak incident. AFRs were low 11s throughout, I don't think it was the tune. The injectors flowed the same for all 4.
Is there anything else that could have caused it that I should worry about?
I know you guys are trying to save money and technically the stock ecu can do well but come on people...its 2021. You can't ignore how much more even budget standalones can give you today over stock evo 7/8/9 ECU. Theres no getting around the stock ECU's logging limitations.
There is usually an imbalance in flow over the stock manifold from cyl #1 to #4. I think the numbers are somewhere on this forum. That can contribute to lean/rich conditions per cylinder that could have been compensated by per cylinder fuel tuning (and ignition timing if you convert to sequential ignition). Per cylinder EGT is one way to do it but I think dual knock sensors to figure out which cylinder is knocking may also work....at least thats what I'm trying on my own setup.
Yes....but it cuts both ways. If something does blow up then you have to blame yourself too. Some people just want to blame others.
Here is my advice if you continue to track your car. Know how it's running. Never assume. Doesn't mean you have to become a tuner, but it will be more rewarding and confidence-inspiring if you have more of a sense of how your car is running health-wise and you could see something that could hurt you in the long run.
. Shiny new tech is nice, but it's skills that makes the real difference.P.S. Once you do pull the trigger and go stand alone, if you modify your engine to take advantage of all those advanced features, you won't be able to swap the stock ecu back in. For most folks that means its now a dedicated off road vehicle.
in any case, if no one else has any thoughts, i guess no other chanegs will be made. i'll pick up the car this weekend, do some mileage on the break-in, and then flush and datalog. so basically, new block, new oil pump, new oil cooler, washed everything else, and bypassed the fpr and deleted the balance shaft. not sure what else could cause it if the tune was on target the whole time, so i will give it a go.
I think your failure is kind of in the freak accident category. I have seen a fair amount of solenoids like that break from the plastic getting brittle. The only way I could see avoiding this would have been proactively replacing the solenoid, or removing (bypassing) it. If I'm not mistaken, its function is to block vacuum signal from the manifold while cranking, so you get more pressure at the rail. Maybe it could have been picked up during an inspection if you were going around wiggling stuff. I kind of accidentally did that with my factory BCS a long time ago when I was working on the car. Went to remove a line and the nipple just snapped off. At the time it was running the stock boost line, so it probably wouldn't have been too bad, but if it was like a plastic 3-port that could easily have led to an overboost condition.
this freak accident was a very, very expensive one. at least not oil starve though
while cranking? according to RS, it compensates for fuel pressure under boost, so i guess if it fails then the car runs lean under boost. i didnt see that in the video but i guess it could happen fast.
One thing you could do though is talk to your tuner about getting that wideband safety feature setup. I don't know if it would have saved your motor, but it might have. I'll post a pic of what those settings look like in a bit.
if it's a line to the FPR solenoid, then if it popped off, the fuel pressure wouldn't rise with boost. Then it would lean out.
This happened a bunch when the Evo 10 first came out. The FPR hose would slip off the intake manifold pressure source and Kaboooom, or if your lucky, you catch it at idle.
When I was tuning Evo 10's regularly, literally the first thing I would do is zip tie that line.
