In the grand scheme thats not too terrible for drop off and just be done with it. My last motor splosion cost about 5500 for the motor build (and I got the block for effectively $50) and had to do a basic trans rebuild for $1500. And it took a few months to get back on the road.
Just confirming, is this a stock block rebuild? How many miles did they say to run it on the break-in oil?
didn't say specifically but he knows my time frame to the next event so I'm just planning on doing a few hundred miles
Holy TLDR you guys talk more than a bunch of women at a bottomless brunch!
so recently on track i had the fuel feed line from my surge tank to manifold blow off. The haltech reconised the AFR change on the o2 sensor and instantly pulled timing and cut the motor. i was 30psi full boost at 500kw power doing around 200kmh at the top of 5th gear. probably around 6000rpm at the time.
We replaced the hose and clamp and sent it no damage at all.
This. is. why. its. worth. a. better. computer.
This isnt the only time this has happened. Freak failures like this occur especially on track. you need the tools to not only log but to automatically have safety cut outs.
Ive had my drysump pump belt snap also at high speed and RPM and the ecu instantly recognized the oil pressure drop and killed the motor, No damage done.
Dont under estimate the value of spending a little bit on an aftermarket ECU. i dont even have gauges in the car anymore because you just cant monitor or react fast enough. $1500 for a decent ECU is cheaper than $8500 for an engine
Also Kyoo on your failure. do you run a flex fuel sensor?
Dallas have you packed my hubs yet
And who makes the best tubular rear subframes?
But Ive heard enough about safeties potentially ruining a race but saving a motor that would have ruined the race anyways to get me on board. We arent professional teams here, just hobbiest out to have some fun so a little forethought to save us from our lack of forethought is money well spent.
I'd be interested in the tubular subframe discussion as well. I know I was talking to Dan over at Diamond Race Cars recently and they have some in stock right now (front and rear). But if I was in NZ, I would probably just go with Racefab.
How many of you guys are running tubular subframes and was there a noticeable difference in handling or response? Or was it mainly the weight savings that made you switch?
Yesss! I have the label here just need to drop off. Huge slacker tho, should have sent out last week.. ugh, damn work has decided to crush my soul.
Maybe move the ECU discussion to a specific thread?
https://www.evolutionm.net/forums/mo...ts-thread.html
No proper motorsports ECU is only $1500 actually working in a car. The harness alone is $500-$1200. Then add sensors for all the things people are wanting in this thread, etc.
