I've had small vac leaks buck about and the ECU does it's best to compensate which shows close to 14.7 +/- .3. Just "looking" at the IC pipes doesn't do anything. I typically melt/wear out some of the vac caps on the intake manifold every 3-4 months.
Lots of things happened this weekend, but one super weird one.... Came back from last run and clutch pedal was on the floor. WTF?
Popped it back up after a quick check under the hood and it was all good.
Visual Inspection: There is definitely clutch/brake fluid out of the slave dropped down on the splitter
Guess: Either slave is leaking or I over extended it.
I have a lot of clutch travel adjusted in cause the stupid exedy is warped.
Now that you mention it, the time I tried COP, I had similar problems. It's why I run OEM now (plus I don't run enough boost to justify). Do you have stock coils/wires to try?
So question for the motorsport folks here. Im pushing coolant, enough that I have to bleed the coolant system after each event. Basically let it cool enough to open radiator, put funnel on rad, fill with water, then warm up to get all the bubbles to push through. After an event Im putting about 30-40oz back into the system. I let the funnel sit on overnight and dump the overflow so it has enough room to catch all thats blown out.
I need to get the engine to last the rest of the season before I can do a full teardown and surface everything.
Thoughts on what I could do,
Next option but couldn't get done before next event,
- Swap in APR 625+ and torque to 100-105
- Pull some timing
- Pull Head and swap gasket
- Swap ARP 625+
- Sendit
Eh, I don't think that'd "magically" fill a gap large enough to loose 40oz in such a short time. If there was gasket there in said gap I have my doubts it's still there with the abuse it see's. Just put some stop leak in it you'll be fiiiinnneeee
If you're not seeing it on the ground/splitter, and it's not enough to change the exhaust smell/color, could be in the turbo? Whats the logs say on temp?
Swapping the gasket is definitely the ideal direction. I just have less 10 days to do it which is fine but no chance to recover if something goes wrong like a seized turbo bolt or something.
Another aspect though, if its going to have an issue we'd probably rather know now since we can just take the Model3 instead.
Looks like its time to start stripping parts off the head.
