Originally Posted by ayoustin
The block had never been surfaced. It was a completely original longblock. Unless you're saying the factory finish is subpar.
I measured the deck on the block, it wasn't warped at all, which is why I didn't get it decked. The head was warped around .002" so I only got the head decked. Head gasket leaked shortly after rebuild. Tore it down again, got head and block decked .001", no more issues. Both times fairly high end CBN decking mills were used.
I've never had an issue swapping heads/gasket in a built motor where the deck is more fresh.
Originally Posted by EVO8LTW
If you have the head o-ringed, do you still need to deck it every time you pull it? Also, thoughts on re-using ARP head studs?
Oring'ed needs decked, and then the groove recut deeper.
Head is off and out getting skimmed. No major warping but certainly low spots will appear when just a thou is skimmed. Hoping it doesnt take much but should have it back today or tomorrow to reassemble.
Now to address the power steering pump, leaking axle boot, cracked slave line, and drop .2-.3deg of camber all around.
Thanks for this. I still have my old, flakey alternator sitting around. Couldn't find anyone local to rebuild it but I may give it a shot myself.
Although the combined price of those replacement parts adds up to more than 2X a remanufactured alternator, so maybe I'll be getting some aftermarket replacement parts.
Also, the alternator replacement job isn't as easy as it looks. It's not exactly hard, but I greatly underestimated how much time and effort it was going to require because it looks like it should be a quick job.
I think ideally, you would diagnose what's wrong with your alternator and just replace that component. There is a bunch of info on diagnosing the alternator in the factory service manual. If you're just looking to do a refresh, new brushes and bearings would be good.
Lol, Spare motor is in my future. But partly just cause I like building motors. Once we move I can go get a junkyard block to get started. Id like to have a spare of everything but the hard part becomes doing spares with some of the more expensive parts like diffs.
One reason to have spares, theyre only getting harder and harder to find. Need to collect!
Got to remember also some of us have cars that are a more modified and extreme than others and some people here are just casual racers.
Ive actually been meaning to build up a spare motor for a while. ive got 2 spare transfer cases. 2 ring n pinions, a RS rear diff spare, full voltex front end etc. cause you never know what you might break and when ur in a championship its all about being able to get back out there for the next race
Does anyone know the spec on how much grease to put in the axle boot? Ive been leaking for a few events and going to get a better clamp on one. But It'd probably be good to pull that end apart, clean it, refill with CV-2. Just not sure what volume it takes and cant find any reference.
EDIT: Nevermind, found it!
3.5oz Outer
5.1oz inner.
3.5oz Outer
5.1oz inner.
