Dallas already showed you the math. Your FSAE example has almost no moment length acting on it. It's also a low bend angle, which lowers the total bending load going through that joint..
I'm going to see myself out of this convo now, like everyone else has. Everyone seems to be on the same page about this except you, and if what's already been said here isn't registering for you then there's nothing more I can say to convince you otherwise.
I like you, not too snotty. Not sure what youre talking about tho. That example is the most popular "Rod End in Bending" in the FSAE world. you're telling me you're better than the judges who will "fail" anyone who uses rod ends in this manner? can you all get on the same page if youre going to tag team. please
Did you look at "the math"? Dallas spent time determining what force a section of the arm is getting. Maybe he's focused on the Momentum/STM units. I wasn't so the "break" is in different points, which is a big miscommunication especially taking about very simple machines called "levers". My car will not see a 2" compression or else something else will break, but sure let's consider his scenario. Like I said, double it I dont care, I just want to know what amount of force will bend an m16 stainless steel threaded rod, then I would like to know what breaks the bigger threaded rod on the GSP unit. It took me a bit to process his concern tho, i wasnt sure what type of failure is concerning.
will it happen in reality? I have a degree in Engineering, In Electronics tho but we have taken courses in all types of engineering. Including Engineering Ethics btw. I'm not an "engineer" because I didnt take the board exam. I.T. is where the easy money is so I just used my degree to open doors. A lot of people wont agree, I thought engineering is full of shiet when I was in college. I mean why do we need all that math to find out if it burns up/crack/bend/fits? In reality, Joe Shmoe will just need a higher gage wire/better concrete/stronger thicker bolt/bigger box. Even the dang FS people suggest a bigger REIB is FINE dammit lol. it's not rocket science
I am not trolling, but if thats what it looks like, fine. I am ESL and I am elated I figured out "threads in bending". I have not encountered this phrase before and took me a while to even google this mystery (to me). "Threads on a lever" jeesus
I just wanted to bring this to light. I never understood probably because a lack of deep technical knowledge, but I've always seen heim or spherical bearings radially loaded in off road racing like Baja and so on, but axially loaded in power sports. Ie snowmobiles, quads, etc . . . Are they technically different joints? Different coverage of the hemisphere ?
- Q: What is the axial static load capacity of Aurora Bearing Company’s rod ends?
- A: For Aurora two-piece rod ends, the maximum axial static load capacity is recommended to be 15% of the ultimate radial static load capacity. For three-piece rod ends, the maximum axial static load capacity is recommended to be 10% of the ultimate radial static load capacity. However, on three-piece units, factors such as race material, body material, and dimensions may affect the axial static load capacity.
I'm going to be dividing my attention between Honda and Evo parts but all the stuff I already offer along with a few things I haven't teased yet will be on the site when it launches
rockauto also jacked up the price of the rear left, randomly. going over to my buddy's tonight to give one last shot at pulling the rear sensors out. if not, i think i'm gonna go with the $30 "economy" sensors and roll the dice i guess. if one ends up bad, how will i know which one it is? will there be a CEL? or do I need to do it by process of elimination?
Good example is HKS spark plugs are just NGK plugs with HKS stamped on them and twice the price lol.
also one to look at especially if your lowering the car with the new uprights is to re route the looms inside the front guards above the wheel. When you lower the car you can hit these looms over bumps and wear through the cable for the sensor, this is quite a common failure ive seen on evos which have been lowered and then tracked.
Soon! My business partners and I just recently talked to a website builder about it so hoping to have something in the next month or so. Earlier today I got our FB page rolling: https://www.facebook.com/WunderladenRacing
It tells you which sensor is bad. Ive run the cheap ones for years been fine. Just because something is more expensive doesnt make it better than the cheaper option every time. most of that stuff comes from the same place and is rebranded.
i'll take a look at how thoes are routed. on the fronts, dallas included a very nice holder for the abs lines. in the rears they are kind of out of the way.
- Rear camber and toe locks (can be bought separately or together)
- Evo 8 reverse cam sensor housing (will have a kit for both housings on the 9 head soon)
- Ethanol sensor mounts that bolt onto the firewall, no modifications required
- Coil on plug ignition mount plates
- "Dual cooler" brackets for center grille mounted oil and power steering coolers
- Firewall block off plates for people who delete HVAC and the heater core
- Billet rear transmission brackets (works for both 5 and 6 speed but only LHD)
- Bladed rear sway bar (very adjustable, uses bearings so minimal deflection and friction, multiple bar thicknesses)
- Rear camber arms (still debating which route I want to go, right now am considering an arm that uses stackable shims to adjust length)
- Quick release door hinges (allows the door to be removed with no tools, to make loading and unloading easier, these will likely only be done in occasional group buys)
- 5 speed shifter cables, since OE are NLA
- Rear AP brake caliper brackets, uses OEM disc to retain parking brake and keep consumables easy.
In the front they are routed above the wheel well liner but underneath the metal frame of the wheel well so if the bump stop on the strut doesn't engage soon enough, the tire will wear through the liner and rub through the wire harness that's there.
