Old Jun 30, 2021 | 04:50 PM
  #3406
EVO8LTW's Avatar
The professionally wrapped inconel heat shielding is very nice, but it is pricey. I know that typical "blankets" can sometimes work to a point (Tial recommended them for its wastegates), but I understand they also tend to crumble and fall apart on track driven cars. Anyone have any experience with Heatshield Products header armor? The specs are promising and it looks good.
Header Armor website
This DIY turbo shielding video and the material (which is on ebay) also got my attention:
Old Jun 30, 2021 | 06:54 PM
  #3407
mazdabish's Avatar
Originally Posted by Balrok
Love my blitz as well. Tyler's 52mm you speak of was ...ok. I wouldn't go as far as saying "71hta sized" though because it uses a 54mm turbine vs a 49 or something on the 71's. 71 spool was 20psi by 3100rpm vs 3900 rpm on the 20g. Quite the difference on track. But it looks like your spool is even later then that?
Eh, just bear in mind the chart goes to 31psi at 4400rpms. I would imagine 20psi is likely around 3900rpms. I also kept seeing a P0011 code (MIVEC) that was likely the wiring too during/after the tune (GSC S2 Cams). Its a Evo 8 Turbine/10.5 Exhaust Housing with 71/52mm 7+7 Compressor and Evo 6 Compressor Housing. It comes on super aggressive like a light switch with tons of torque...and definitely made power. Even at 26psi it was still making 430whp on E85 (track map I had detuned a bit).
I'm happy with the turbo given the price, customer service, and power it made.
Old Jun 30, 2021 | 07:25 PM
  #3408
kyoo's Avatar
doesnt it trap heat into whatever it's covering? i guess sometimes that's better than letting the heat permeate in the bay
Old Jun 30, 2021 | 09:46 PM
  #3409
Ayoustin's Avatar
After seeing woven turbo blankets catch on fire from head conduction on track I would never run one on my car. The inconel shielding is definitely nice but not cheap.
Exhaust heat = thermal energy. Lost exhaust heat is lost energy and about 75 - 80% of what spools a turbo is thermal energy so not letting it escape is good for performance. Letting it escape to the engine bay just creates problems for other system components.
Old Jun 30, 2021 | 10:46 PM
  #3410
kaj's Avatar
kaj
To a point. I could swear I've seen a turbine housing get so hot, it "warped" and sent oil (which caught fire) into the engine bay. IIRC.
Old Jul 1, 2021 | 03:55 AM
  #3411
EVO8LTW's Avatar
I’d prefer shielding radiant heat to “trapping” the heat in the metal, just from a longevity standpoint of the header and turbine, provided other components don’t get cooked by the heat. I’ve also seen header wrap trap oil from leaks and lead to car-b-que, so I’m also very weary of anything woven (including exhaust wraps in the engine bay or under the oil pan).
Old Jul 1, 2021 | 06:32 AM
  #3412
RazorLab's Avatar
It cost me $1300 for:
Exhaust manifold shield ($400)
Turbine housing shield ($300)
Downpipe shield (the whole downpipe!) ($465)
V-Band shields ($50)
Compressor housing back shields ($95)
I don't think that is much at all if you start pricing out other pre-made alternatives that probably aren't as good.
My only issue with Inco is it "hides" everything, making it nay impossible to spot an issue or looks for cracks and such. Or is it serviceable?
Of course it's serviceable. You can take it off and put it back on. It's just like OEM inconel.
As far as cracks, if you don't use crap stuff, then it shouldn't be cracking all the time.
I recently swapped the turbo and have this photo of the inconel shield off. One con I can say is that, since the inconel shield really is shielding things, it makes it a pain in the *** to get to bolts and such to take things out and reinstall. But it's possible, obviously...
Old Jul 1, 2021 | 07:47 AM
  #3413
EVO8LTW's Avatar
You are right that those prices aren't so so bad relative to the total cost of the turbo kit. Is that all held together with inconel safety wire? Do you re-use the wire when you take it on and off?
Old Jul 1, 2021 | 08:07 AM
  #3414
RazorLab's Avatar
Yes, all safety wire. They gave me extra as a whole spool of it with the order. Probably last me a couple of years easily.
Old Jul 1, 2021 | 09:15 AM
  #3415
Ayoustin's Avatar
Good safety wire isn't expensive. Just be sure to grab safety wire pliers or you'll hate life trying to get everything twisted nicely.
Old Jul 1, 2021 | 12:24 PM
  #3416
Kevin.'s Avatar
Originally Posted by Kevin.
loving the old school amsoil filter
This is a first lol.
Injen customer service couldn't have been better. Shipped a replacement out right away. I thought those days were gone.
Old Jul 2, 2021 | 08:10 AM
  #3417
kyoo's Avatar
lmao - well, that's nice at least.
Old Jul 2, 2021 | 08:35 AM
  #3418
Balrok's Avatar
After how many miles?
Old Jul 2, 2021 | 09:22 AM
  #3419
kaj's Avatar
kaj
I'm impressed. I can't remember the last time I had decent customer service from any company.
Old Jul 2, 2021 | 04:28 PM
  #3420
kyoo's Avatar
dumb question - how do i attach the hose to the back of the duct? i dont tape it on do i?
