Its a really quick and easy check. If you adjust the rod at the pedal too long is when you run into issues which would be trying to raise the pedal. If you go too far it leads to inconsistent pedal engagement point and pedal pump-up. If you dont have that, then its probably adjusted fine.
But that valve will probably prevent motive from doing too much bleeding. Might be wrong, but would be easy to test by slightly pressing in the pedal to get off that valve with the motiv pressurized and clutch bleed open.
Most likely cause of this is when you get dirt or a small stone etc caught in there.
Seeing as it's happened twice now I don't think it's a stone or debris. You only need about .040" (about 1mm) to wipe out the crank sensor with the trigger wheel, I've measured. My thrust measured at .005" so I'm still not quite sure what's going on. Won't know for a while either unfortunately.
I ordered parts for all four endlinks from McMaster racing.
If I do the front links, I might also re-drill the stock FSB. I've never played with FSB adjustments before, so it might be nice to adjust it a bit and see what happens.
Don't want to speak on his behalf bc seems I misquote in misinform but IIRC hes on OEM 88mm crank. Also, what strikes me as odd was if it were machined wrong youd think it would fail immediately and in this case I think it worked until it didnt then replaced and failed again in short order. To me that means something changed.
Out of curiosity, why do all four links? Also, Cusco makes brackets that allow for adjustment if you decide you don't wanna try to drill through the bar.
There's only so many things that can cause this. Good luck, dude. Wish I knew enough to help.
Most of the nuts and bolts come in packs of 5-10 from McMaster. It was only about $20 extra to get the rod ends to do the front links too. I probably won't install them, but now I've got the parts on hand if I ever need them.
I imagine I'll find a smoking gun when I get the chance to pull the motor back apart but for now the car is taking a backseat while I try to find a new job and get moved into a new place which will hopefully have enough room to work on the car.
I just stayed a new job this week...a little stressful. Career change...
