Bolts Vibrating Loose
Old Aug 26, 2019 | 01:29 PM
  #31
heel2toe's Avatar
It's certainly possible but I think most of my issues are a result of me and well, just function of hammers on it no BS stiff mounts and revs. My limiter is set to 9200 and Im revving it to over 9 grand consistently (which btw is epic for autox to extend 2nd gear without changing FD to the 4.31 or 4.11).
So yeah its certainly possible its a balance issue but the short block was built by ER so confident that was done right and fully balanced. Car has an ATI damper and I'm also using an Exedy Twin HD, however neither of those were balanced with the rotating assembly but honestly what I'm doing isnt that unique so goes back to what I think is function of what was mentioned prior and Im, well as you put it need to hit the gym
Old Aug 26, 2019 | 01:37 PM
  #32
kaj's Avatar
kaj
9K. Holy Honda motor, Batman!
Old Aug 26, 2019 | 02:21 PM
  #33
LetsGetThisDone's Avatar
Flywheels and dampers are *never* to be balanced with the crank. If they get changed in the future you would then need to pull the entire motor back down and rebalance the assembly. The crank is balanced by itself, as is the flywheel and damper.
Pretty much SOP for a 4g that doesn't have a stock frame turbo choking it up.
Old Aug 28, 2019 | 04:53 PM
  #34
V.8MR's Avatar
I use blue/serviceable loctite on anything that doesn't get hot like exhaust/turbo stuff. Has worked well for me so far. But my car is a garage queen. She vibrates though without BS and stiffer engine mounts.
Old Sep 5, 2019 | 06:51 AM
  #35
EVO8LTW's Avatar
Wow...I have a built 2.0 and try to limit to 7500 most of the time on track, winding to 8k only when necessary to hold a gear. I try to be mechanically sympathetic to all of my cars. Even my S2K rarely sees above 6k (a waste I know).
PhantomBlackEVOX
Aug 15, 2019 05:28 AM
TheBigD
Feb 16, 2014 10:08 PM
evopowered8g
Oct 7, 2013 12:29 AM
Most Hated
Apr 3, 2012 10:17 AM
maxims4g63
Oct 26, 2010 04:04 AM
