4g63 engine stand bolts
Old Aug 14, 2019 | 11:54 AM
PhantomBlackEVOX's Avatar
Veteran: Army
Hey everyone, recently picked up a Harbor Freight engine stand for a 4g63 I have. It didn't come with a trans so I don't have the bolts. So I picked up the right thread bolts at if I recall a 50 or 60 length. Seems like once they go through the arms on the stand, they wont go very far into the motor. I am concerned that the weight may break the 1/4 to 1/2 inch that goes in. I have never put a motor on a stand before...is this normal? For those out there who have a similar stand can you recommend or let me know what dimension bolts your using for this?
Thanks guys!
Old Aug 14, 2019 | 12:32 PM
blackline's Avatar
5 Year Member
You can use longer bolts with washers, just sure they are the same thread pitch
Old Aug 14, 2019 | 12:36 PM
Veteran: Army
Originally Posted by blackline
You can use longer bolts with washers, jsut same sure they are the thread pitch
I've already picked up 2 different lengths, just not sure how far into the motor they need to go to be "safe" I guess is a way of putting it.
Old Aug 14, 2019 | 12:52 PM
blackline's Avatar
5 Year Member
I would say more that 1/4, maybe 1/2. Sorry, don't have much more info than that.
Old Aug 14, 2019 | 02:37 PM
LetsGetThisDone's Avatar
It's a 12mm bolt. They need minimum of 12mm of thread engagement.
Old Aug 15, 2019 | 05:28 AM
Veteran: Army
Might be okay with the ones I have if its 12mm into the block. Guess ill try it out and see how it goes. Thanks man!
evopowered8g
Oct 7, 2013 12:29 AM
17pstockcar
Aug 17, 2012 11:12 AM
Babs
Mar 21, 2011 11:24 AM
maxims4g63
Oct 25, 2010 11:12 AM
TURBOit
Lancer Engine Tech
Mar 3, 2004 05:15 PM
