AIM Solo vs Solo DL on Evo8
Old Sep 19, 2019 | 01:22 PM
LetsGetThisDone's Avatar
I'd go AEM over Link any day. Haltec pro2500 is also a good option.
Old Sep 19, 2019 | 07:38 PM
Ayoustin's Avatar
Meh, based on all the second hand experience I have, I've noticed that Link has the best custom service by far and almost all of their products are directly compatible with Aim stuff with little or no hassle.
Old Sep 20, 2019 | 01:28 PM
EVO8LTW's Avatar
I’m sure I’m going to reveal my ignorance here, but since I have electric senders for my aftermarket coolant temp, oil temp and oil pressure gauges, could I just tap those wires if I went with something like the Race Tech DL1? I also have an SD conversion, so also my GM AIT and 3.5 bar Kavlico MAP sensor? And maybe my Zeitronix WBO2 too?
Old Sep 20, 2019 | 02:35 PM
Not sure why you'd want an ECU that can't really do full time closed loop AFR, and when it is in closed loop, it's slow... q
Old Sep 20, 2019 | 03:07 PM
RazorLab's Avatar
If it has 0-5v inputs, then yes.
Old Sep 20, 2019 | 03:14 PM
Pal215's Avatar
Right. The only grunt work you have to do after that is assign corresponding numerical values for each measurement of voltage inside the data logger software. Otherwise it can't know that 2.33v from a map sensor means 10 psi (example only, not correct value).
Old Sep 21, 2019 | 10:00 AM
Balrok's Avatar
Exactly. You take the 5v wire, usually not red or black but white or blue or something, and put it into the DL-1 Analog tap. Then you simply need the formula for volts to Fahrenheit/PSI which is different for every sensor but it's usually on the sensor manufacture site or datasheets. Like zeitronix has: http://www.zeitronix.com/installation/mapinstallation.shtml.
It also has a formula builder in linear or other graphing methods. If 0v equals 1psi and 5v equals 100psi then it'll build the calculation for you.
Old Sep 30, 2019 | 11:37 AM
EVO8LTW's Avatar
After doing all the research, I opted to get a used AIM Solo for now and keep a lookout for a good deal on a VBox video set-up. I really like the demos of the Circuit Tools software, but will play around with the AIM software for now without linked video. It’s crazy how expensive the dedicated motorsports camera setups are relative to the image quality. I get that that’s not the point, but still...
Old Sep 30, 2019 | 11:44 AM
RazorLab's Avatar
Have you looked at RaceCapture yet? I use it on my 10, where it is a ton better because of CAN but you can still use it on normal non CAN with gopro integration as well.
Old Sep 30, 2019 | 11:54 AM
Balrok's Avatar
A lot of programs are integrating/using the newer GoPro's that have GPS enabled to do after-analysis much like the big box programs do for way cheaper too. My buddy is using harry's for live timing and then RT's gopro analysis (but there are many others). Basically the same functions on a budget.
Old Sep 30, 2019 | 12:59 PM
RazorLab's Avatar
For reference, I used RaceRender to combine my RaceCapture date + my GoPro footage:
Old Sep 30, 2019 | 01:41 PM
EVO8LTW's Avatar
I’ve been using HLT with GoPro and external GPS for a couple years, but the wifi and bluetooth connections (not to mention batteries) are not 100% reliable for me, and it can be stressful messing with the devices after getting strapped in if they aren’t cooperating. I really want a system that is more foolproof and also would like to be able to do lap to lap comparisons with video linked to GPS data in near realtime. For just processing video for YouTube, RaceRender or similar is fine, but that’s not really ideal for analyzing laps and finding time while you are at the track between sessions.
Old Sep 30, 2019 | 02:23 PM
RazorLab's Avatar
Yea, I don't blame you. RaceRender was a pain in the *** to use.
Old Oct 1, 2019 | 07:31 AM
Balrok's Avatar
Agreed, Render is great at making videos quickly and easily but it lacks that review component. I made my Roebling video with it last.
Old Oct 1, 2019 | 08:21 AM
Ayoustin's Avatar
This has been on my mind a lot lately and I'm in the same boat. I want to make things simple and streamlined for data and video stuff. I'm trying to make it a project for this winter to move to a standalone and get a Solo 2 DL. The Aim stuff can pull a good chunk of CAN data from every popular standalone option and having all of that data integrated with the telemetry should give quick feedback and lap review.
