Trunk Lid Bracing
Old Nov 11, 2019 | 06:31 AM
  #31
Balrok's Avatar
You're right but your stuck on the wing still. All you say is true, it's mad stiff and putting said force on the TOP, BACK, of the trunk via the uprights. Thus the TRUNK deflects because all of that hardware is floating and not tied down to anything. Try hanging off a stock trunk mounted wing and you'll see what we mean, only takes 40ish lbs.
Old Nov 11, 2019 | 09:33 AM
  #32
Bee-Raddd's Avatar
Pretty much. u can watch the front middle literally lift. especially if you dont have a full framed stock lid anymore.
I have big end plates on my wing too and the guys on the pitwall reckon u can literally watch it twist as you increase in speed. Its almost like having active DRS haha
Old Nov 11, 2019 | 10:46 AM
  #33
Ayoustin's Avatar
I've sat on my trunk with no observable deflection. Like it's been said, multiple times, replace the rubber mounts with metal and you won't have trunk deflection.
Old Nov 11, 2019 | 11:31 AM
  #34
kaj's Avatar
kaj
I can see my trunk lid slightly deforming on the front edge of the wing mount, so looks like it's lifting a bit. That concerns me.
Old Nov 11, 2019 | 01:08 PM
  #35
Bee-Raddd's Avatar
go pro it.
Old Nov 11, 2019 | 01:24 PM
  #36
kaj's Avatar
kaj
Originally Posted by bee-raddd
go pro it.
I mean looking at the trunk. I can see where its lifted a bit and changed shape.
Old Nov 11, 2019 | 01:42 PM
  #37
Bee-Raddd's Avatar
Yea i know your a believer i meant for the guys who dont think theres any deflection or movement lol
Old Nov 11, 2019 | 04:15 PM
  #38
Ayoustin's Avatar
You didn't plastically deform steel with downforce...
Next time I'm back in Chicago I'll take a vid of my trunk not flexing.
Old Nov 11, 2019 | 07:02 PM
  #39
Dallas J's Avatar
Veteran: Army
Heres how much my trunk flexes with about 25lb load pushing on the strut.
Old Nov 12, 2019 | 02:55 AM
  #40
Ayoustin's Avatar
https://www.youtube.com/watch?v=tTix4El0VYk
Stock rubber stops?
Old Nov 12, 2019 | 06:55 AM
  #41
Dallas J's Avatar
Veteran: Army
Yep, but they are screwed up really tight. You have to close my trunk with a little bit of effort.
Old Nov 12, 2019 | 08:37 AM
  #42
Ayoustin's Avatar
I have to slam to my trunk to get it to latch. No deflection, fixed with < $10 of hardware.
Old Nov 12, 2019 | 08:47 AM
  #43
Dallas J's Avatar
Veteran: Army
Thats not going to change the fact the front edge is lifting from flex in the hinge.
Old Nov 12, 2019 | 10:52 AM
  #44
Bee-Raddd's Avatar
Exactly. and hes just wobbling it by hand. air force on the whole surface area at say 180kmh will be well beyond what your capable of applying by hand
Old Nov 12, 2019 | 10:53 AM
  #45
Bee-Raddd's Avatar
and just to add to the above ^ the biggest thing we found is its not the rubber stops or anything pushing down thats the issue. its literally the front edge twisting up away from the car that was the most noticeable thing. Especially if youve got a proper wing that generates decent downforce and its quite far back on your lid.
