Trunk Lid Bracing
Old Oct 22, 2019 | 12:10 PM
V.8MR's Avatar
Trunk Lid Bracing
How are you big **** guys who arent chassis mount bracing or stiffening the deck lid?
Old Oct 22, 2019 | 01:37 PM
Ayoustin's Avatar
I'm not.
As long as the wing is mounted at the outer edges of the trunk (like stock) where it goes over the chassis there will be minimal deflection.
Old Oct 22, 2019 | 01:59 PM
V.8MR's Avatar
Can you take some pics of the elevator bolts and the underside of your mount?
Old Oct 22, 2019 | 03:40 PM
Ayoustin's Avatar
Unfortunately not. The car is still back in Chicago and I probably won't be going back until the most recent batch of splitters are cut which won't be for like another month. It's pretty basic though. Just use a longer bolt on the rear most bolt location and put a female threaded adapter on it on the inside and then thread the elevator bolt into the female adapter.
Old Oct 24, 2019 | 05:03 AM
EVO8LTW's Avatar
Not my car.
Old Oct 24, 2019 | 08:50 AM
Balrok's Avatar
I've tried the adapter/bolt brace method and they just vibrate loose and make a hell of a racket.
Old Oct 24, 2019 | 10:52 AM
V.8MR's Avatar
How about the lid itself? Thinking of using big washers on the underside to grab more sheetmetal too.
Old Oct 24, 2019 | 11:28 AM
heel2toe's Avatar
Big washers on the underside will only assist with it not pulling out but wont do anything with the forces pushing down. The mounting plates to your wing are quite wide too so I honestly think you'll be OK as is.
Plus do you even drive that car!?
Old Oct 24, 2019 | 12:53 PM
V.8MR's Avatar
Lately all i gots is a few hrs here and there to wrench on it. But my wife will be done with school next year so then ill be using it lots more.
Old Oct 24, 2019 | 01:37 PM
kyoo's Avatar
school in stl?
Old Oct 24, 2019 | 02:00 PM
V.8MR's Avatar
Originally Posted by kyoo
school in stl?
She goes to Chamberlain College of Nursing. We were extremely lucky that there is a campus here in STL. So she was able to transfer from the Chicago campus fairly easily. But man clinical rotations and stuff are really hard on the family. Starting next week I have to split my days off to Monday and Weds to cover for her and be with the kids.
Hence the car sits lol. But we're also moving into winter so its all the same I guess.
Old Oct 24, 2019 | 03:57 PM
EVO8LTW's Avatar
At what point does a wing need to be chassis mounted? How much pressure can the trunk take? I want to add a real wing this winter and don’t want to end up with any potential of it coming off mid-corner. The wreck of the Element Tuning STi at VIR in the uphill esses really sticks with me.
Old Oct 24, 2019 | 05:46 PM
Ayoustin's Avatar
There is no set point when a wing needs to be chassis mounted. All big wing failures I've seen are because of failed carbon trunks or the wing itself. Trunk mounting to a metal trunk will never give you issues unless you mount it poorly or give inadequate load distribution.
Old Oct 24, 2019 | 05:51 PM
EVO8LTW's Avatar
I wonder if some wing failures may be the result of trunk deflection though, where the AoA gets beyond the spec that the wing can withstand and then the wing comes apart?
Old Oct 24, 2019 | 07:04 PM
Ayoustin's Avatar
No. Too much AoA just means considerably more drag. As long as you're not running some crazy triple element wing you'll be fine with a trunk mount.
