RPM at 170mph?
Old Apr 24, 2020 | 06:03 PM
  #31
cficare68's Avatar
I think I was around 7,000rpm in my car doing about 187mph (approximately) 5 spd 4.11 Final Drive w/ JDM Evo 8 5th gear.
Old Apr 24, 2020 | 08:31 PM
  #32
EVO8LTW's Avatar
I'm sure your car is fine. Generally EGT/AFR/Timing doesn't universally apply. Each car needs some paying attention to see what it likes
What turbo is holding 23psi out the top?
BBK Full. It will hold much more, but I’m just running less for the track (and because 93 octane).
Old Apr 26, 2020 | 10:03 PM
  #33
Driv200's Avatar
I guess I was thinking the external reservoir was helping. It’s better than before when I had huge brake delay at the end of long straightaways. Still improving. Is it possible the added ABS is unable to keep up with 10/10ths driving on wider R7’s? Thinking about unplugging ABS and comparing. Need to see if ABS is coming on to soon? Or not allowing peak threshold braking. Maybe new Radical AP Pro 5000’s are also stressing the ABS program???? I should start a new thread on this. You experienced the same ever?
Old Apr 27, 2020 | 09:30 AM
  #34
Balrok's Avatar
Yep sometimes, get tons of laps of it not doing it, then the one hard pedal but still braking. It's enough of an issue that it makes me count 1 1thousand before applying brake after my super long straights. I've also adopted jackie stewarts driving style of easing both instead of immediate threshold braking up front followed by immediate gas. Makes it much more predictable and faster because you don't overslow or underslow. This is not caliper related.
Old Apr 27, 2020 | 10:01 AM
  #35
LetsGetThisDone's Avatar
Getting vacuum in the brake booster is different than the manifold. My car without a vacuum pump shows vacuum just as quickly in the intake. Only time I have hard pedal is autocross, or if i get into abs
The vacuum pump helping brakes makes sense. I thought you had it running on the crankcase for additional ventilation.
Old May 15, 2020 | 05:41 AM
  #36
frostEvo's Avatar
tscompusa
Dec 21, 2011 12:27 AM
J-ROC
Sep 26, 2007 06:11 PM
EVOONYOASS
Jan 12, 2006 11:05 PM
ctevo
11
Dec 7, 2004 09:57 AM
kromix
Nov 2, 2003 08:10 PM
