schroth harness
Old Aug 13, 2004 | 10:29 PM
BrownPoop's Avatar
Question schroth harness
thinking about getting this for weekend track events (like NASA hpde4)...
http://www.soloracer.com/rallye4.html
has anyone used this in the EVO?
comments/thoughts/experiences please.
tia.
Old Aug 14, 2004 | 07:26 AM
chrisw's Avatar
yes I have one installed already. Installation simple, do a search and you will find many threads discussing this
I like the scroth harnesses, their great for autocross and track day events. The harness is DOT approved for street use.
Old Aug 14, 2004 | 10:21 AM
Bogie's Avatar
I use it also, I concur with what chrisw wrote. Do a search, there is a nice install thread on this particular harness, with useful pics to boot!
Old Aug 14, 2004 | 10:42 AM
BrownPoop's Avatar
doh!
forgot to search..... thx guys.
Old Aug 16, 2004 | 06:56 PM
metaphysical's Avatar
Registered User
I have them, their very nice. But I want to get a single mount and find a place to mount them up high. I have a rally 4 setup now, mounts down by the rear seatbelts.
Old Aug 16, 2004 | 08:07 PM
MagEvoVII's Avatar
Yea I have these as well but not much padding on the strap so need to get the pads which schroth makes also. I like Takata or Sabelt more because the belts are thicker ... but they cost more too.
Old Aug 17, 2004 | 08:37 AM
tsi90awd's Avatar
I have the Rallye 3 belts. I installed them within a week of buying the car in April 2003. I use them for autocrossing and driving school weekends. They are mounted using the stock lapbelt bolts and the rear mount for the passenger shoulder straps. They work really well. I use the stock belts for normal use. On the race track, I put the stock belt over the Schroth harness.
These Schroth belts have a latch that disconnects the shoulder strap. When it is disconnected, the belts on the front seats easily push to the side and behind the seats. The rear shoulder support strap just hangs down on the rear seat backrest. I hardly notice that they are there.
The only problems that I have had is that the stock rear shoulder strap doesn't retract quite as easily (doesn't matter much though since I rarely have passengers in the back) and the black plastic housing/clip thing that covers the antisubmarine loop sometimes comes loose when the rear shoulder belt is disconnected. Not that big a deal.
Personally, I don't think there is any advantage to the Rallye 4 over the Rallye 3. Both connect through the same kind of release latch, so the breaking strength is about the same. It is much easier to mount the single shoulder strap of the Rallye 3 to the rear shelf so that it is loaded horizontally.
Old Aug 21, 2004 | 01:03 AM
bobaab's Avatar
try this thread for instructions and discussion:
https://www.evolutionm.net/forums/sh...=point+harness
Old Aug 27, 2004 | 08:15 AM
Bogie's Avatar
Check out what harness comes standard on the UK's MG SV-R. Taken from September's issue of CAR magazine.
Old Aug 28, 2004 | 01:09 PM
Kayaalp's Avatar
2-inch wide 4-point harnesses are fine...unless you have a high-speed frontal impact (see "submarining") or a rollover (see "quadriplegia"). There's a reason why most organizations will not allow these types of harnesses at high-speed events.
But they're great for keeping your butt planted at auto-x.
Emre
Old Aug 28, 2004 | 01:33 PM
BrownPoop's Avatar
I am not using the harness for auto x... I am using it for road course events...
Old Aug 28, 2004 | 02:54 PM
Kayaalp's Avatar
Check with NASA too see if they will allow it. Most organizations will not (for the two reasons I listed above).
Emre
Old Aug 29, 2004 | 12:54 PM
BrownPoop's Avatar
Doh!!!!
I already ordered one for this weekend..... should I just use my stock seatbelt?
please give me a quick lesson in submarining and quadriplegia... I searched for it and 300000 links popped up with other irrelevant info...
tia
Old Aug 29, 2004 | 12:56 PM
BrownPoop's Avatar
I used to use a big 3" 5 point harness in my older cars but they were a ***** to get on and off... I though the 2" 4 point was safe for tracks like streets of Willow etc...
Old Aug 29, 2004 | 12:57 PM
EvoBig16G's Avatar
nice!
