Check Engine Light P0455 EVAP Large Leak
Subscribe
Jan 13, 2011 | 09:04 AM
Hi Everyone,
My check engine light has recently turned on. I got the code P0455 for Evaporative Emission Control System Leak Detected (gross leak). I have changed the gas cap, but the check engine light still turns back on. Does anyone know of a way to fix this or know a good mechanic in the Dallas, Tx area. I can't find the leak because I don't have a fog machine. Oh by the way I just moved to Dallas.
Thanks,
Ronald
Reply 0
Jan 13, 2011 | 09:15 AM
Take your car to Evolution Dynamics and talk to KevinD, he can get you squared away very quickly.
Reply 0
Jan 13, 2011 | 09:16 AM
http://evodynamics.com/
They're in Lewisville and will get your taken care of.
Reply 0
Jan 13, 2011 | 10:13 AM
Cobb Tuning in Plano is open now and all day until 6. They can fix your car as well.
www.cobbtuning.com/plano
Reply 0
Jan 13, 2011 | 11:04 AM
i can help you out. give me a call 817-776-2170. i'll be at the shop tomorrow evening, and josh can do the boost leak test during the day if you want it checked out sooner.
i have all the parts in stock you could need to fix the evap system, but i suspect it will be something really simple (likely the vacuum line from the charcoal canister to the intake manifold solenoid valve)
Reply 0
Jan 13, 2011 | 12:44 PM
Quote: i can help you out. give me a call 817-776-2170. i'll be at the shop tomorrow evening, and josh can do the boost leak test during the day if you want it checked out sooner.
Thanks! I will try to contact you sometime, but I'm kinda busy today and tomorrow. I will be stuck at work for a while. Hopefully the timing will work out
Reply 0
Subscribe
