Boost Question!
Old Nov 19, 2006 | 03:29 PM
evoracingstar's Avatar
Boost Question!
i was wondering what 1.97 kps is in psi? bc i cant figure out to figure this out. and i havent got my boost gauge yet. i hit 1.97 kps thats what it read on my profec b boost controller but if anyone could help me i would appreciate it thanks
Old Nov 19, 2006 | 03:35 PM
evobeatsti's Avatar
http://www.onlineconversion.com/pressure.htm
Old Nov 19, 2006 | 05:14 PM
what is the conversion though i cant figure it out if u could help me thanks
Old Nov 20, 2006 | 09:56 AM
mannymartinez's Avatar
i think thats 28psi. whis is a lot... unless u have a bigger turbo?
Old Nov 20, 2006 | 11:13 AM
IMR-TIM's Avatar
1.97 bar = 28.57243 psi And if on a stock turbo.....
I think you might be spiking in a high gear. I was getting high readings when load was being increased under acceleration in 4th & 5th gears on the hwy. 1st -3rd at WOT was just fine. My profecB II hit a 1.79 once (stock turbo), and I was told to adjust the settings on the controller. I lowered the settings, and so far so good. Even though the controller was reading higher numbers than what should have been by the settings, my boost gauge on my pillar was reading accurately. the profecB can be a tricky b*tch to really get right. Good Luck.
Old Nov 20, 2006 | 08:34 PM
what ur settings set to in low mode? i got my gain at 15%. the set gain 1.70. and it says for the peak 1.97. yeah i run it on stock turbo i think it holding around 19 20 psi right now though. one thing i am haveing trouble with is turning the profec b boost controller into psi mode i tried it so many times and everthing dont seem to work! but thanks alot guys i appreciate it
Old Nov 21, 2006 | 04:10 AM
avs's Avatar
avs
Not to be a dick. Did you graduate high school ?
Old Nov 21, 2006 | 12:18 PM
IMR-TIM's Avatar
Just a little help so you don't over boost or blow up:
Here is the link to the profecB spec II controller pdf file for everything you will need for it. It's on GReddy's site. To change the setting to psi from kpa is on page 14 in the pdf. But your settings will be different when programming between psi & kpa. Keep that in mind.
http://greddy.com/img/PHP/products/pdf/682.pdf
Also, here is a link that someone wrote up on programming, it's in teh Evo how to section: https://www.evolutionm.net/forums/sh...ad.php?t=75594
Here are my settings (NOT PSI) Stock turbo but with a few mods....
Set = 51%
Gain = 7%
Set Gain = 1.11 (16.09 psi)
Warning = 1.48 (21.46 psi)
Warning Limit = 2%
....and my peak has been holding at 1.50/1.51 (21.75 psi / 21.90 psi)
Hope all this helps, and download a conversion program into your computer. It's a great tool. I use it all the time when it come to these things.
-Tim
Last edited by IMR-TIM; Nov 22, 2006 at 05:45 AM. Reason: typo on settings...ooops
Old Nov 21, 2006 | 12:23 PM
kreionic's Avatar
IMR-TIM, You have your set gain at that high? Do you have any issues at all? The set gain is when the profec starts to takle control of the boost. I didn't think the unit would even kick on that high?
Old Nov 21, 2006 | 01:15 PM
IMR-TIM's Avatar
OOOPS....sorry about that, typed my old settings. Took them from the notebook on my desk, and forgot to update it. I have a notebook with all different settings I have tried and with the results. I edited that other post, thanks for the heads up. I had to go to my car to get the settings I'm running that work for me. With those settings I'm running great. I had issues with the other settings. Fixed the notebook entry too
Old Nov 21, 2006 | 07:41 PM
i figured it out lol i wasnt really thinking! o yeah by the way im only 16 and yes i do drive an evo. and i am in highschool too still ahah
Old Nov 21, 2006 | 07:43 PM
hey thanks alot i appreciate all the help no i got to go get a flash and dynoed see waht i got for some numbers!
Adio
For Sale - Cars For Sale
12
Nov 29, 2012 05:15 AM
Goldfinger978
13
May 18, 2011 10:18 PM
Goldfinger978
Oct 11, 2010 09:25 AM
kpS13
Northwest Region
35
Aug 31, 2010 06:59 AM
donbrown34567
Jun 26, 2009 01:36 PM
