Connecticut Evos
Old Sep 29, 2010 | 03:15 PM
  #2551
nperkins's Avatar
if you are at 7psi you are on wastegate pressure. Check your vacuum lines for the turbo..
Old Sep 29, 2010 | 06:51 PM
  #2552
qucifer's Avatar
Ah, good to know. I'll double check the vacuum lines, is there anything else that would cause that? Blown BCS?
Old Sep 29, 2010 | 08:32 PM
  #2553
ethan169's Avatar
aren't you using a MBC Bryan? If so then your bcs is not in the picture anymore.
Either way at 7 psi i doubt it's just a boost leak something else is up for sure. As neperkins said Check the lines goin to your bcs. On should be from the compressor housing the other should be going to your waste gate actuator. Also if your on factory boost control the lines need to be a certain length and have a pill or two inline if I'm not mistaken. I think it's actually just one pill in there. A boost leak resulting in 7psi peak would cause massive overboost for your turbo trying to catch up and produce the pressure that the bcs is holding out for. Fluctuations, sluggish operation, slow spool, and lots of knock/ high loads on the logs are indications of leaks.
Anyway I have a pretty decent pressure tester that I use often and shop air at my place. Your welcome to it whenever you need it.
Good luck
Ethan
Old Sep 30, 2010 | 04:11 AM
  #2554
qucifer's Avatar
Good luck
Ethan
I am back on the BCS since my last time at The Shop in the wake of the whole blowing-out-the-dipstick thing. So I don't have the MBC anymore.
I was skeptical that it was a boost leak, but I am trying to think of things I can test for before Sunday. Now knowing that 7psi is wastegate pressure, it makes all kinds of sense that the issue is wastegate actuation. I looked at the vacuum hoses from the BCS to the turbo as best I could and they seemed ok, however I am not sure how thorough I was...I'll do it again next chance I get.
Might a pinched vacuum hose cause the problem, if one exists?
Could the ECU be doing something stupid? I don't know how limp mode operates, or if it would be obvious that I was in limp mode.
If it were a vacuum issue, wouldn't it be presenting as a rough idle too? Or does the turbo have it's own vacuum loop?
Old Oct 1, 2010 | 05:00 AM
  #2555
nperkins's Avatar
Maybe the BCS went bad, or came unplugged or something?
As far as dipstick blowing out... This is what I did on the rally car..
Never have to worry about it again..
Old Oct 1, 2010 | 05:14 AM
  #2556
qucifer's Avatar
The BCS is still plugged in, but could definitely have gone bad.
As far as the dipstick goes, I want it to act as a pressure relief valve. If for some reason pressure is building up, I would rather it blow the dipstick out than the oil pan gasket or something.
Old Oct 1, 2010 | 06:27 AM
  #2557
silkey00's Avatar
Hey guys. Still waiting to hear from people for the Fall Foliage Run. If i dont get much interest, then i'm not even going to try to plan it. The last couple get togethers we've had there were only like 5 or 6 of us there. I'm not going to waste my time if people arent going to show up.
October 23rd. Who can show up?
Old Oct 1, 2010 | 08:01 AM
  #2558
qucifer's Avatar
No can do on the 23rd, sorry.
Old Oct 1, 2010 | 10:12 AM
  #2559
silkey00's Avatar
suck.
so..... opinions..... i need seats unbelievably bad right now and i see no reason why not to get a knock off set of Brides. Wadya think?
Old Oct 1, 2010 | 11:45 AM
  #2560
allinevo's Avatar
Why do you think that Jake stopped planning it..... Evo owners in general are like this,they all say they are going to go and then on the last minute they all have something else planned. Just look at this thread from the begining(170 something pages ago) and you will see what I am talking about.
Make a LIST and let people who say that they are going to put their name on list,then see who actually shows up.....
Old Oct 1, 2010 | 12:02 PM
  #2561
nperkins's Avatar
The PCV system is made to handle this.. The dipsticks blow out because the PCV just can't evac fast enough... not a HUGE deal.. If you put a dipstick spring on, the dipstick can still move, it just wont BLAST out and stay out.
suck.
Show or go? Are you going to track your car (Not Drag, TRACK).. If you are, i recommend real seats... If its more of a show car / toy, no reason to not go knockoff..
Old Oct 2, 2010 | 07:48 AM
  #2562
silkey00's Avatar
probably mostly show. ill probably only track once a month or every other month.
Old Oct 2, 2010 | 09:07 PM
  #2563
04EBevo's Avatar
Tuner Network meeting tomorrow anyone? Ill be bringing a new owner with me. What time do people usually show up there?
Old Oct 2, 2010 | 09:18 PM
  #2564
silkey00's Avatar
Well guys, we had another work day on the monster. Here's a couple of pics i snapped. Enjoy.
Old Oct 3, 2010 | 05:30 PM
  #2565
silkey00's Avatar
Here's a couple more.
