Philadelphia's Classiest Drunkards
Old Aug 23, 2011 | 06:30 AM
  #26821
chu's Avatar
chu
Is it a whining noise when you're on the highway? I replaced both front wheels bearings not too long ago. Would be a good idea to do extended studs at that time if you're already thinking about it. I need to do my rear bearings also. But nothing in the rear has been removed since 2003, and I know the axles are probably seize in there! Something I dont want to deal with!
I need to get something like this.
Old Aug 23, 2011 | 06:38 AM
  #26822
grillpt's Avatar
Originally Posted by AlwaysinBoost
finally getting rid of those bolt-on spacers huh.
If I have to do a bearing, yes.
Just making some funny ticking noise when I first start moving, I would say around 10mph. It sounds like rocks hitting the heat shield behind the rotor. I think I heard a few clunks before I pulled in the driveway too.
Its hard to hear anything on the highway cause my tires are so loud, so I really don't know.
Old Aug 23, 2011 | 06:41 AM
  #26823
AlwaysinBoost's Avatar
wheel bearing is my guess.
Old Aug 23, 2011 | 06:42 AM
  #26824
Tims2006MR's Avatar
^ Try loading an unloading the bearings by going left and right. See if one way makes it louder or quieter. Could it be a shim on the brakes hitting the axle?
Old Aug 23, 2011 | 06:51 AM
  #26825
chu's Avatar
chu
Mine whine a bit at highway speeds. Took them out with Thai's help, and the play was crazy.
Old Aug 23, 2011 | 07:03 AM
  #26826
grillpt's Avatar
I don't know... just gonna get it looked at. I don't really have much time to play with it myself. Being as the left side takes such a beating at NJMP, I have a feeling its the bearing as well.
Old Aug 23, 2011 | 07:11 AM
  #26827
Tims2006MR's Avatar
why bad wheel bearing?
Because racecar every week
Old Aug 23, 2011 | 07:27 AM
  #26828
honda-guy's Avatar
Originally Posted by grillpt
So does any one know if the TF extended studs are long enough to run a 20mm spacer? I was reading up on it a little last night, and I think they are, just want to make sure... I've read they aren't as long as the ARP's, but there also less than half the cost.
I know Thai has them on his car and seems to like them from his post I read.
I don't think the TF studs are long enough for 20mm spacers. Its says on there site that it can bond 14mm spacer max. I was going to get apr front studs for 20mm spacers. The TF studs are perfect length for the rear hub so you don't have to remove the hub to install.
I would never use bolt on spacers on track.
Old Aug 23, 2011 | 07:28 AM
  #26829
dek0026's Avatar
I think it's a wheel bearing.
Old Aug 23, 2011 | 07:46 AM
  #26830
igo4bmx's Avatar
are TF wheel studs just APR studs to their specs?
those guys like to just do one offs with a manufacturer and say it's theirs ROFL
Old Aug 23, 2011 | 07:50 AM
  #26831
grillpt's Avatar
Don't call them knock-offs, Chu will get mad.
ARP's don't seem so expensive, I thought they were gonna be more. About $80 seems to be the going rate for 10 of them.
Old Aug 23, 2011 | 07:51 AM
  #26832
you don't drive hard enough for it to matter.
I'm going to say its a wheel bearing issue...
I have some sweet Alwaysinboost spec intake valves. they're custom bent to my exacting specifications and meet ANSI 1.2.5643.69 standards. Custom mendrel bent stems means air will flow smoother into the cylinders creating a venturi effect and increasing gas mileage as well as performance.
  #26833
chu's Avatar
chu
No, its totally different. THe TF studs look like oem, but are longer, and zinc coated, or whatever makes tham that gold color. The ARP are longer, and has the taper end. ARP are prolly much stronger, but also cost much more.
Old Aug 23, 2011 | 07:52 AM
  #26834
spittin a little hate:
https://www.evolutionm.net/forums/sa...ight-mods.html
found a post where this guy said he paid 11k for the car but I'm waiting to see how he reacts before I post the link.
yeah I'm a little bored and bitter...
Old Aug 23, 2011 | 07:53 AM
  #26835
chu's Avatar
chu
EBAY has studs, similar to APR, but half price. Get them!
