Philadelphia's Classiest Drunkards
Old May 11, 2010 | 07:47 AM
  #5011
robertg's Avatar
Good luck Dan and Josh. If only I weren't moving Saturday I would be out there.
Old May 11, 2010 | 07:49 AM
  #5012
chu's Avatar
chu
try not to fail so much....
Old May 11, 2010 | 07:52 AM
  #5013
CatalystGod's Avatar
^^ ouch!
Old May 11, 2010 | 07:59 AM
  #5014
BBS's Avatar
BBS
Josh, you should autox with your hood open. Maybe someone will push some fuses and up your mbc!
Old May 11, 2010 | 08:11 AM
  #5015
grillpt's Avatar
Where you moving to Robert?
Thats not right...
Old May 11, 2010 | 08:32 AM
  #5016
BBS's Avatar
BBS
All of you guys tuned by pete. Whats your fuel cut? Is an 8k rpm fuel cut realistic on the stock valvetrain? I dont see why 8k would be so bad on our rod/stroke ratio but I'm not so sure on the valvetrain.
Old May 11, 2010 | 08:38 AM
  #5017
grillpt's Avatar
Most of the guys on here are tuned by Pete, not everyone though. My car was tuned at CBRD, he set my fuel cut at 7780rpm I believe.
One of these days I need to get a fresh tune on my car, once I get these dang parts on...
In reference to what your asking I think valve float is the reasoning for not going over 8k, unless you have an upgraded valvetrain.
Old May 11, 2010 | 08:44 AM
  #5018
BBS's Avatar
BBS
So on stock valvetrain = nono. Now that Im done with suspension/aethestics, id like to concentrate on engine modifications. Having owned the car since new, it has been stock this entire time. My goals are one thing, powerband. I want a broad one and a useable one. Not a 35r setup thatll hit peak boost at 5k+ and have only 2k rpms worth of useable power. I'm thinking a bbk full with the necessary supporting mods to rev it out to 8k. Seems like the bbk has stock spool but breaths better than the stocker in the 6-8k range. PUMP GAS ONLY! Stop trying to horde me to your e85 ways.
Old May 11, 2010 | 08:48 AM
  #5019
dek0026's Avatar
e85 or go home.
Old May 11, 2010 | 08:56 AM
  #5020
Oh boy, and I thought I was loosing out big time waiting for 2 years before I got a chance to do anything.
I like how you think.
I think the BBK will serve you right. It is by far the best combination of peak power and early spool for the CT9A evos.
Again, I like how clear-cut you are in your requirements. I see you don't want to give up your DD capability for a measly few HP.
Old May 11, 2010 | 08:57 AM
  #5021
Originally Posted by dek0026
e85 or go home.
Its amazing how many there are in the Philly area, but there are absolutely none in NJ. There's only a couple upcoming pumps I think here. Would make the switch in a heartbeat if it was as abundant as it is in the MidWest.
Old May 11, 2010 | 08:58 AM
  #5022
chu's Avatar
chu
I dd on E-85, whats the problem?
Old May 11, 2010 | 09:04 AM
  #5023
not saying its a problem just because of the fact that its E-85. Its a royal PITA if you run out of E-85 and there's no stations nearby. A Pump gas tune to swap the maps would help, but its a hassle nonetheless. Like I said, I'd make the switch in a heartbeat if it was more abundant.
In my case, the fact that I have to drive through Delaware, MD and DC to go to VA every other weekend and that they don't have many stations either is enough to keep me away from E85. Don't get me wrong, I am all about the advantages E85 has to offer, but availability is an issue for me. I do drive a lot between states.
Old May 11, 2010 | 09:07 AM
  #5024
BBS's Avatar
BBS
LOL. Were not all fanatical like you! Driving to allentown with drums in the back just to get your fill -__-. The correlation between crack addicts and e85'ers, is becoming more and more apparent O__o.
Old May 11, 2010 | 09:08 AM
  #5025
colonelfox's Avatar
Me too and I frieking love it. The car has never felt faster and more drivable all around. Plus I have this strange urge to eat Chinese food everytime I floor it.
Everyone has to be there by 8am.
I have to BE THERE by 8?
