Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
Congrats to Steve Murphy
Old Feb 15, 2005 | 08:43 PM
NDgsx's Avatar
Steve doesn't like to brag online, so I told him I would do it for him . Yesterday he dynoed his Evo at dynoauthority in Redmond. With basic bolt ons he made 299 hp at 6,750 and 281ft lbs at 4,750. In comparision at stock Evo on their dyno made 219.9hp at 6,000 and 243.6ft lbs at 3,750rpm. Factoring a 20% drivetrain loss (remember this is a mustang dyno which tends to read lower than a dynojet) that's 374 crank HP currently.
The curve is even nicer than the peak numbers suggest, from 5,500 to 6,250 it is ~75ft lb gain, the hp curve hits almost 300 from around 5,750 all the way to 6,750.
The mod list is short:
Pina Motorsports 3" exhaust with a standard cat
Pina Motorsports FMIC, 24"x12"x3.5" core
Pina Motorsports 2.5" lower IC pipe
Pina Motorsports 2.5" straight route upper IC pipe
Pina Motorsports lightweight battery
AEM intake pipe and filter
Works throtle body
Apexi SAFC
Hallman MBC
Stock cams, stock cam gears, stock intake manifold, stock o2 housing, stock exhaust manifold.
This is still with a factory fuel system, while I highly recomend 660s and a fuel pump by this point it is possible to do without them. After Steve decides between works or Al for his computer the 660scc injectors will be going in.
FMIC, ic pipes, and battery tray pics www.pinamotorsports.com/gallery/album57
HKS SSQ no longer being used, I recomend the greddy typeS
Exhaust pics www.pinamotorsports.com/gallery/album56
Old Feb 15, 2005 | 09:03 PM
jj_008's Avatar
That seems about right w/ those mods.
Old Feb 15, 2005 | 10:02 PM
DahakaJR's Avatar
Is the Pina web site still under construction?
I can't tell in the pics, but does that exhaust come out side ways or straight?
I can't stand the sideways thing.. I wanna find a good exhause with a straight exit.
Thanks..
-DahakaJR
Old Feb 15, 2005 | 11:45 PM
Airpoppoff's Avatar
hollur, nice steve...
Old Feb 16, 2005 | 08:18 AM
jman425's Avatar
nice ! i gotta go in there and get another dyno with the "new" evo settings. the only mods i've put in after this last graph were the test pipe and custom map from Shiv.
Old Feb 16, 2005 | 08:33 AM
jj_008's Avatar
Hey jman425, is that a pump gas dyno chart? Where is your dyno chart from Matrix? You know the dyno where no one could break 300hp on pump.
Matrix had the lowest reading Mustang dyno, but it looks like they have fixed something since I have been seeing some 380-400hp STi's w/ bolt ons. And we all know that can't happen.
Old Feb 16, 2005 | 10:26 AM
jman425's Avatar
hehe, i couldn't crack 300 either on that Matrix dyno, especially with that V3 beta version that was causing my car to stall. ended up leaving around 8 that night . nine hours sitting in that room was not something i wanna go through again. when you headed north to pdx again ?
Old Feb 16, 2005 | 11:03 AM
NDgsx's Avatar
DahakaJR, yes we're still working on the website. I finally got the online ordering up and running, but I haven't actually got the products in. It's hard to find time when I have four engine rebuilds in the shop.
Back to the subject, yes the exhaust exits straight. We didn't want to make another N1 style exhaust, there are enough of those out there already. We also just redesigned the downpipe to fit the MR, I just need to change the jig now.
DG Motors
Evo X Dyno Results
16
Jul 19, 2009 04:05 PM
hanahawaiian
Northwest Region
71
Mar 23, 2008 11:36 PM
TURBODAWG
73
Feb 9, 2006 08:38 AM
EricR
Northwest Region
11
Sep 9, 2005 08:25 AM
SlowEVO8
Northwest Region
Apr 24, 2005 06:43 PM
