Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
It begins now.....
Old Mar 11, 2006 | 02:44 PM
  #61
jj_008's Avatar
Originally Posted by Kyle R
I'd be careful with the wastegate hose touching the stainless braided line. Looks like the setup is treating you well though, are you going to take it back to the drag strip now?
The wastegate hoses were only there until I could get my boost control issue solved. I might make it back to the drag strip if there is an EVO meet that ends there. Don't expect 11's from me. I'll be happy w/ a 12.9 at 115mph on pump .
Old Mar 11, 2006 | 03:28 PM
  #62
EVOGOD21's Avatar
Hey jj how come 12.9? if i don't run 12.7 or 12.5 i am gonna cut my dickk off!
you'll do better
Old Mar 11, 2006 | 05:37 PM
  #63
mikiblueeyes's Avatar
I am sharpening the instruments HAHAHAHA
you'll do better
Old Mar 22, 2006 | 12:36 PM
  #64
FahKen Evo!'s Avatar
Here are some graphs compared to my GT3076. Red & black are the GT3076.
Not too bad for not making 20psi until 5500rpm .
The GREEN line is the APEXi Turbo kit or is it the torque line of the GT3076R? I am Guessing that the Black Line is the APEXi Turbo Kit just the WHP and then the is no Torque shown? If so then wow that is nice.
I got the manual boost controller today and it helped a little bit. Boost is now going to 22psi (I think most is due to creep) and spool up is around 5200rpm now. I can here the wastegate opening around 17psi. Apexi told me the wastegate spring is a .8 bar, but it must be around .6. Hopefully, my new 1.4 bar spring will be entering the country soon. That should get my spool up around ~4800rpm.
Where did you get the spring from?
Also, 34PSI and under 500WHP is not that impressive so I am wondering if it was the tune or what? Those are GT3076R numbers for sure or even a 50 Trim number.
Old Mar 22, 2006 | 06:43 PM
  #65
jj_008's Avatar
The green line is the Apex'i turbo at 20psi. The graph is showing HP over time.
I never received the spring since they stop making them.
The turbo is only rated at 550 crank HP. It makes roughly 30hp more then my GT3076 at 30psi. If I would of used uncorrected numbers, like alot of people on this forum, then my 494whp would be around 530whp
Old Mar 22, 2006 | 07:08 PM
  #66
It seems to spool a LOT better then the GT3076R but then again I believe your GT30 kit was internally gated and had a caste manifold? So that may be the Issue. I would love to see how it runs with a 20PSI spring. What is the issue with the wastegate?
Old Mar 22, 2006 | 07:19 PM
  #67
jj_008's Avatar
The GT3076 spools up to 20psi about 700rpm sooner then the RX6. Peak torque was reached at 4300rpm w/ the GT3076 and 5000rpm w/ the RX6.
I had a RnR GT3076 kit w/ a Tial 38mm wastegate.
The wastegate fell apart and was fixed by Apex'i. A 20psi spring won't help spool up w/ the way I am running boost control now. The only problem I have is I can't hold over 34 psi.
Old Mar 22, 2006 | 07:28 PM
  #68
Hmmmm, that much slower in spool? Damn Maybe I should just stick with a GT35R. You also described a different way to control boost? Why won't a stiffer spring help?
Old Mar 31, 2006 | 03:56 PM
  #69
War Monger's Avatar
More updates:
My spool time has also decreased by 400-500rpm. I hit 24 psi at 4300rpm now in 4th gear..
Wait, does this thing spool as fast as the GT3076R now or is it still slower? According to your graphs, even with the leaky wastegate, the green line shows more power across the board until the VERY top. Would you say that this turbo is better then the 3076R?
Old Apr 1, 2006 | 11:36 AM
  #70
jj_008's Avatar
Better is up to the user. It's a lot laggier then my GT3076R. I would like to try a smaller RX6 turbo if I can find one for under $2000 .
Old Apr 1, 2006 | 02:41 PM
  #71
War Monger's Avatar
Maybe get a smalled hot side? Yours is too big so topend is great but lag sucks. BTW, anything lagier then a GT3076R SHOULD be a Gt35R.
Old Oct 5, 2006 | 08:36 AM
  #72
Willie Dynamite's Avatar
So how is it after six months?
Old Oct 5, 2006 | 09:45 AM
  #73
Bioxide02's Avatar
He doesn't own the car anymore.. I do now.
Old Oct 16, 2006 | 11:27 PM
  #74
BlownIncome's Avatar
Are you still running the same Turbo setup he was? If so, what are your thoughts about the Apexi kit?
Old Feb 17, 2007 | 07:56 AM
  #75
TURBODAWG's Avatar
Bump. Back from the dead. Anybody else running this kit? Or any updates from the new owner of jj 008's car?
