bad lifter or spun rod bearing ??
Originally Posted by Jaylenospoolboy
Turbo Junkie, a little off topic, but how do you like your turbo kit thus far. Is it what you expected or is it part of the problem?
. i think i need to do somemore fine tuning and think 450 awp at 25-26 psi on race gas is doable.
Originally Posted by EVSEVO8
Good to hear. Not a major problem.
You may want to talk to your tuner before you remove the balance shafts. The engine is going to make more noise w/o them. This may fool your knock sensor and retard your timing.
my car didn't make any extra knock noise from removing the balance shafts according to my logs. you will notice a tiny bit more vibration through the pedals and steering wheel. its not a very fun job also.
I was wondering who installed your cams because it has alot to do with the balance shafts, and ive heard from two local tuners that they are seeing alot of the balance shafts out of phase on evos from others installs.
Hassan
103
Aug 5, 2023 11:37 AM
memphis raynes
26
Apr 5, 2015 11:25 AM
dipsetinallday
Jun 28, 2009 11:28 AM
