Widband Gauge recommendation????
I was reading a bit on the AEM and I may be wrong, but I thought that I read that you could make your own serial cable/connector that would run to the laptop, cause it does have a serial output wire.... I may be going with the AEM cause it seems pretty dummy proof....
Also don't forget to angle it correctly. The angle should be in the instructions but if the angle is wrong while the car is parked moisture can settle on the probe and what not.
aggieEVO
May 1, 2015 01:17 PM
Q@EvoPowerMods
Oct 30, 2007 06:54 PM
aem, gauge, hot, innovate, innovative, melted, uego, widband, wideband, wiring, x16, ziektronic, ziektronicscom
