Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
JDM IX bumper Install HELP
Old Jul 19, 2007 | 04:37 AM
haze1995's Avatar
Question JDM IX bumper Install HELP
I need help installing my new JDM Evo IX bumper. If anyone has experience with this I would apprciate this very much. I would attempt it myself but I am out of the country. I am trying to have this done for HIN. Please help me!
Old Jul 19, 2007 | 07:51 AM
Kevindanger's Avatar
The best bet is to take it to a shop.
Old Jul 19, 2007 | 08:34 AM
haze1995's Avatar
I dont think it would require a bodyshop, just someone who has done it before.
Old Jul 19, 2007 | 09:03 AM
at least someone w/ a rivit run
Old Jul 19, 2007 | 09:06 AM
TURBevO8's Avatar
I am letting a local hot rod shop do mine only because I need to modify my HKS 30th Anniversay exhaust. I dont know how to TIG, let alone stainless. So I figure I might as well do it all at once. Did you consider your exhaust? Are you sure the one you have will fit the IX rear?
Old Jul 19, 2007 | 09:17 AM
This is true I forgot to mention that to Haze. I didn't worry about it before cause I had the greddy ti
Boostin4g63's Avatar
i have a Evo 8, i also wanted to put the JDM Rear Diffuser Bumper. My question is will the JDM IX Bumper fit on the USDM Evo 8's? Those things look clean though.
I have stock exhaust at the moment and plannin on gettin Buschur Racing Bullet Muffler TBB. Will this be ok with the JDM IX Bumper. I mean fitment wise, will everything fit right?
Old Jul 19, 2007 | 09:19 AM
The fitment could be the same for an 8 and 9. Ask the shops that sells it For BR ask them too if it will fit
Old Jul 19, 2007 | 09:31 AM
SaVaGe_MinG's Avatar
wait haze, i thought seph was doing it??
Old Jul 19, 2007 | 09:53 AM
outlaws69's Avatar
Its not hard at all... just do it it will only takes like two hours. the HKS exhuast will clear, and it will fit only a 8... look
Remember I told you you have to modified the lic plate bracket... if you shorten the bracket and use after market lighting, thats how it would look.
the exhuast rub a little on the inboard side aft section. you will have to trim it back about 1".
Old Jul 19, 2007 | 10:04 AM
haze1995's Avatar
I have the Espelir JGT 500 Exhaust
Old Jul 19, 2007 | 10:05 AM
hksevoix's Avatar
if its a rivet issue which I know is going to be a pita I can take it to my shop and get the bracket removed from your usdm bumper and give the install a shot, I have a pretty good knowledge of how it is to install, plus I'll be doing my own when it gets here ~ Jon
Old Jul 19, 2007 | 10:08 AM
haze1995's Avatar
I have researched and this is a little more envolved than I thought. Seph may not be up to it.
Old Jul 19, 2007 | 10:09 AM
hksevoix's Avatar
I have the same exhaust its going to rub a little and stick out quite a bit, eventally you'll need to go to an exhaust shop to have it modified, but in the mean time it'll be fine
Old Jul 19, 2007 | 10:21 AM
chewy, this urs? nice
