Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
Possible spun rod?
Old Jul 29, 2009 | 08:47 PM
hanahawaiian's Avatar
wow. i over 60k miles on my IX and have more power and Boost.. and use AMSoil 10w30 syn.. never had problems.. time for you full built! or Stroker the motor..
you gonna build all motor yourself?
Old Jul 30, 2009 | 03:53 PM
Sassaphrass's Avatar
no im having a shop build the motor, i dont nearly have the tools nor the knowledge to that myself. were not stroking it out but we are going with a 20mm oversized kit from ams
Old Jul 30, 2009 | 05:01 PM
JohnBradley's Avatar
.020...not 20mm (though that would rock)
DO NOT UNDER ANY CIRCUMSTANCES TURN THE CRANK
They are nitrided and if you turn it the crank is useless and will start to destroy bearings. I would check the oil pump to make sure its not hosed, either because it seized and caused the issue or failed after the oil problem. The material from bearings needs to go somewhere so take it apart (or have it taken apart) and inspected internally.
What shop?
Old Jul 31, 2009 | 12:41 PM
I'm having vtr do the build, ive had them do work on all my cars so i trust them wholly. the kit from ams comes with a new oil and water pump. i was wondering if we would be able to set up a dyno tune appointment at drift office once they get it done? we are gonna have dom put a base tune on it when its complete and i would prefer to drive as little as possible until you guys can get your hands on it.
Old Jul 31, 2009 | 01:38 PM
Yeah, when its ready we can get it done. The tune that is on the car isnt going to change that much so unless its getting larger than stock injectors at the same time it doesnt need a baseflash. Just break the car in, 50-150 miles, and let us know.
Old Jul 31, 2009 | 03:20 PM
the only major change besides the bottom end is BC 272 and valvesprings. we are planning on the car being done on the 8th. so i'll give you guys a call towards the end of next week so we can set something up. my name is Tyler
This is the kit that we are using for the bottom end. using the manley h rods
http://www.amsperformance.com/cart/A...mance.com.html
Old Jul 31, 2009 | 03:46 PM
M8NSTER's Avatar
What up dude!?
Your 9 is going to be sickly fast after all that
You're definitely going to need some new Toyo's when you're done. Provided it ever rains here again
Old Jul 31, 2009 | 04:38 PM
i keep telling u guys they got plenty of tread geez .i know this weather is ridiculous, watch we'll probably have like 10 feet of snow this year as well
Old Jul 31, 2009 | 08:15 PM
fuzzydoodle's Avatar
Should have gotten a 2.4, rather than stroke it, last longer.
Old Aug 2, 2009 | 10:11 PM
I wouldnt even bother putting the BCs in. They wont make any more power than stock cams. The valvesprings like to break as well. I guess its time for another "BC sucks and this is why" thread.
Old Aug 2, 2009 | 10:18 PM
amui07's Avatar
what cams and valvesprings would you recommend then?
Old Aug 2, 2009 | 10:32 PM
dbsears's Avatar
cough* GSC S2 or Kelford 272 and Beehives
Old Aug 2, 2009 | 10:49 PM
Brokenevo's Avatar
Tomei 280 cams haha those were yummy on my car.
Old Aug 3, 2009 | 08:26 PM
interesting to say the least. so would i be better off with stock valvesprings?
Old Aug 4, 2009 | 09:50 PM
This is a BC after 12k-
I did exactly everything I did to the stock valvesprings (8300 ALOT, 8700 once or twice).
BC 272 IX cams make less power than stock. We took out a set and picked up 35whp and alot better powerband. Couple all of this to the fact BC has horrible customer service and it leads me to my belief they are the worst thing to put in any car.
....and Derek called it. S1 or S2 and either GSC Beehives or the FP. I personally use the GSC S2 cams and FP beehive springs.
