Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
Help: Is this my Clutch slipping? Youtube Vid inside!
Old Aug 28, 2009 | 09:32 PM
josel_atr's Avatar
Hi guys,
Please see attached link for the video I took earlier. I was rolling 40 mph at round 2k rpm then just floored the throttle.
http://www.youtube.com/watch?v=hFom72FZbts
Is this my clutch slipping?
Here are some info about my evo:
- 05 evo 8
- 28k miles
- owned it for about 2 months now
- slave cylinder hard line was leaking few weeks ago. the symptom was the clutch pedal was flat on he floor. it was repaired by cutting the hard line and reflaring it. after this, the clutch pressure was back on nice and firm.
- fast forward to this afternoon... i checked it again after taking it out for a short drive. its leaking again but not from the hard line. i think the leak is coming from the slave cylinder itself. but the pedal pressure is about the same, although its a bits sticky
all i need to know if there is a need for a clutch replacement.
i apoligize for the crapiness of the video. i took it using my camera phone alone while cruising.
help.
Old Aug 28, 2009 | 09:40 PM
FedEvo8's Avatar
Try to put it in 5th gear from a dead stop. If you can't get it to roll, you need a new clutch.
Old Aug 28, 2009 | 09:42 PM
fuzzydoodle's Avatar
Once you're rolling you're clutch should not be engaging, at least I believe.
But it doesn't look like you're mph goes anywhere, like you're clutch is in.
I thought the clutch only slipped when you're up in boost/horsepower, which obviously is not at 24k.
Weird, I don't know though. Hopefully someone sheds some light on this.
Really? Does that work? I would think you would have to slip the hell out of it to go in 5th from a stop.
Old Aug 28, 2009 | 09:43 PM
jnut24's Avatar
kinda hard to say from the video...but if you can give us detail on if it goes into gear if so what gears, and if it moves? also tryin putting it into 5th and starting it, it should die right away if not its slipping.
Old Aug 28, 2009 | 09:45 PM
vicksen's Avatar
Slipping clutch is my thought. Probably a result of the clutch not fully disengaging when you had that leak. 28k is not alot of miles, if you're not modded try taking it to town and country. Explain that it wasn't abuse, it was a result of a faulty clutch line.
Old Aug 28, 2009 | 09:55 PM
AznEvoIX's Avatar
Going to need more info. Wish you would've let me drive your Evo last time at FD. That way I could tell for sure..... Because my clutch is slipping. LOL.
Old Aug 28, 2009 | 11:05 PM
yahu's Avatar
Josel, I'm assuming that you were "in gear" when you hit the gas and while no mph gain at first, it slowly started to gain mph toward the end of the video when the rpms dropped back down. If so that is likely your clutch slipping. I would try to get that warrantied (though you are the 2nd owner and I'm not sure how that will fly). Good luck!
Old Aug 28, 2009 | 11:14 PM
josel_atr's Avatar
yes i was in fifth gear.
i was flooring it when the rpm when up then dropped down to around 2k then kind of when up again at the end... i gained speed but it wasnt much...
also, i tried this: 5th gear, from stop try to move forward without stepping on the gas... the evo went forward without stalling.
oh yeah, after doing the flooring test, the car smelled so bad. my buddy said it was the clutch.
Old Aug 28, 2009 | 11:16 PM
josel_atr's Avatar
i know we should've done that... i wish i can be at the deception pass tom but i dont want to risk driving it too far...
Old Aug 28, 2009 | 11:18 PM
That sounds like you're clutch, sounds like its stuck engaged, for whatever reason.
And if you smell it, its definitely sticking.
Old Aug 28, 2009 | 11:19 PM
yahu's Avatar
That really sucks, Josel. It does not seem worth it for you for tomorrow.
Old Aug 28, 2009 | 11:42 PM
josel_atr's Avatar
yea it really sucks big time in soo many ways...
1. i will not make it tomorrow to see you guys and miss a great meet/cruise
2. fast_freddie was going to hook up a tactrix cable to my evo to see whats up
3. we all know clutch replacement hurt our pocket
Old Aug 28, 2009 | 11:51 PM
yahu's Avatar
^sorry buddy. Hopefully you can get warranty work out of it, but I'm not going to hold my breath for you.
Old Aug 28, 2009 | 11:55 PM
josel_atr's Avatar
haha its cool.
thanks for your all input guys!
Old Aug 29, 2009 | 12:44 AM
AznEvoIX's Avatar
Don't you have a DD Civic? =(
I borrowing my aunts car tomorrow so I can come down. LOL.
Edit: Re-reading this again, its your clutch.
Come down to ER! I'll make the roadtrip with you! Weeee!!!! Roadtrip to Portland, while the Evo is in the shop, yes?
