Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
emmissions question
Old Mar 24, 2010 | 12:31 PM
kimsan808's Avatar
emmissions question
I'm up in WA, and i was wondering if my setup will pass regulations, hks 280s 720cc injectors, full exhaust with high flow cat, and and o2 pipe with external dump, my CEL is on all the time for knock purposes, I'm just wondering if anyone up here in WA area know of a place that would pass regulations on what i got?
Old Mar 24, 2010 | 12:37 PM
italianevo88's Avatar
hah probably not but id just take out the guage cluster and take out the bulb so the light is off while your there
Old Mar 24, 2010 | 01:01 PM
Uryelowducky's Avatar
Go get a tune at ER. Problem solved.
nothere's Avatar
you need to have an ecuflash with some of the latest refinements to the obd2.
the test simply checks the ecu for codes, if it reads good you are good. I'd check in with English Racing for the ecuflash flash, although there should be some people local too.
iow, it can be done, although the dump deal is something I have no understanding of. maybe you could put a potato in the dump.
Old Mar 24, 2010 | 01:33 PM
GTisRule's Avatar
English Racing can take care of this. Our emissions are ran by the state so you can't do the lovely California Bribe to pass up here. ER can not only tune your car for good gains, they can help control the CEL to be more or less functional depending on your view of things. (Mine will flash if knock is detected, much more functional than an emissions tattle tail if you ask me.)
Last edited by GTisRule; Mar 24, 2010 at 01:34 PM. Reason: accidently quoted a thread to start typing stuff...
Old Mar 24, 2010 | 04:02 PM
kimsan808's Avatar
Thanks guys for the help, i just returned from the test and failed, I'll deffinitely check out English Racingand ask for their respected advice. as for the readout. It said, P0420: catalyst system efficieny below threshold bank 1, and P0134: O2 sensor circuit no activity detected bank 1 sensor 1. Im gusessing the p0420 is due to the cams, but not to sure about the p0134, i did change the o2 housing idk why its not working.
Old Mar 24, 2010 | 04:10 PM
F0RSAKEN's Avatar
It would be the O2 sensor itself, not the housing. And my guess would be it is your second O2 sensor that is throwing the code/s, which ER can remove completely from the ECU's subroutines thus solving your problem
Old Mar 24, 2010 | 06:17 PM
foam's Avatar
you sure about that?
Old Mar 26, 2010 | 07:25 PM
JohnBradley's Avatar
We can convince the ECU to play nice
Old Mar 26, 2010 | 08:19 PM
Aaron20's Avatar
Move to Island County, no emissions! But really English Racing can help you out.
Old Mar 27, 2010 | 12:13 PM
yahu's Avatar
^or Snoho!
Old Mar 29, 2010 | 10:39 AM
Ryan.Kauz's Avatar
Dont move to Island County. Their fish and wildlife agents are total ***-hats. Its not worth it!!!
Old Mar 29, 2010 | 04:36 PM
yahu's Avatar
^not if you can keep it in your pants and stop fuggin' the fish and/or wildlife!
68wsteve
May 13, 2015 12:55 PM
mike2010X
Clubs
10
Dec 25, 2014 12:58 PM
ImEv0
Pacific Northwest
Sep 29, 2014 02:27 PM
maxGdsm
Feb 27, 2010 03:07 PM
the bastard
Oct 29, 2008 09:17 PM
