Wheel spacers
Old Dec 18, 2016 | 07:43 AM
  #31
Hamman's Avatar
Just ordered a set of 1.5" (38mm) Hub-Centric spacers. Was going to just go with the 25mm, but I like having a bit of poke from the tires. Give the OS a wider and more aggressive stance. Then off to lifting this bad boy!
Old Dec 18, 2016 | 07:52 AM
  #32
Nast_Nas's Avatar
THats a pretty big size spacer. Probbaly way too much, have you seen a 25mm with a different tire size, it already pokes quite a bit. I would look into replacing your oem studs with some extended studs. That's a lot of stress on the oem ones.
Old Dec 18, 2016 | 07:54 AM
  #33
Nast_Nas's Avatar
For reference here's a 25mm on 235/70/15 that's just enough IMO
Old Dec 18, 2016 | 04:07 PM
  #34
Hamman's Avatar
1.5" wil be fine. I am running 215's, that guy has 235's, so that there is 20mm, and he has aftermarket rims with like 3.5BS, much more than OEM. If it's too much, I'll swap them out. I have 1.5" spacers on my Xterra and offroad/wheel the **** out of it. I've done my measuring I'll be sure to report back though.
Old Dec 24, 2016 | 10:04 AM
  #35
Hamman's Avatar
Got my 1.5" wheel spacers installed. Perfect fit, perfect poke, no rub, exactly what I wanted. @Nast_Nas, thanks for the info, but what you thought about 38mm spacers is way off. That picture you showed me is way excessive. For anyone else with 16's and 215 tires, if you want a more aggressive look but not over the top pick up a set of 1.5" spacers. Here are some pics, can post up more if wanted. Went ahead and bed lined the front/rear lower bumpers, wheel arches and sides. Need to go back and touch up some spots still.
FameEvo
Jan 27, 2018 08:00 PM
ElectricBlueIX
Dec 6, 2017 02:38 PM
Bmurray
Oct 16, 2017 05:02 AM
tweakdsm
May 26, 2017 10:33 PM
poonpower
Oct 22, 2016 06:35 PM
