Wheel Spacer Question
Old Nov 30, 2017 | 07:36 PM
ElectricBlueIX's Avatar
So I'm thinking of doing wheels spacers to bring my OEM BBS out flush with the fenders. To those that have done this, which spacers do you recommend? I know this is a divided topic so please respond only if you have experience in the matter.
Old Nov 30, 2017 | 07:56 PM
Raptord's Avatar
Just guesstimating but you'd probably be looking at around 15mm in the front and 5, maybe 10mm max in the rear. You'd probably want at least a small roll in the rear, especially if you went with 10mm, to ensure the wheel and tire has room to tuck into the fender under compression.
Old Dec 1, 2017 | 06:15 PM
LetsGetThisDone's Avatar
15 or 20mm bolt on spacers do the trick.
Old Dec 1, 2017 | 06:43 PM
Rear fender work required. Roll, slight pull or you can do a tight roll as well as bumper bolt relocation
Old Dec 6, 2017 | 02:38 PM
Thanks for the input guys. The rear fenders have already had a slight roll done to them since the previous owner had a wider set of wheels/tires on the car before and it was on coilovers.
I have a set of BC coilovers on it now and might actually raise the rear about a 1/2" to create more room. That would actually make both wheels gaps identical.
bmojito
South Region
May 18, 2009 10:06 PM
Bernie Fincham
Aug 4, 2008 12:21 PM
evodrivesme
13
May 4, 2008 02:38 AM
JDMonster
12
Oct 4, 2006 09:52 AM
