Project Blackout
Old Jul 9, 2013 | 09:45 PM
  #121
LUNARFX's Avatar
Originally Posted by Burtonrider1002
Halogen projectors aren't focused the same as HID projectors due to the way the bulbs output light. Halogen bulbs are 360 degree output, where as HID's by design are side firing/output. Because of this, the shape of the reflector and lens is different, as is bulb spacing from the glass. Some Halogen projectors will output OK with HID's, some will not. Generally (IMHO) HID's in halogen projectors are still better than halogen reflectors of any sort, which is why I have no problem helping out any of the ES guys with HID or other lighting/optics questions.
Now, this is the first I've seen the actual output of HID's in the Outlander Sport's Stanley projectors, and I must say that the cutoff is pretty sharp for a "plug 'n play". There is some noticeable glare above the cutoff, but it doesn't look to be too intense, so it shouldn't blind oncoming traffic. The cutoff shape is also a bit different. Yours seems to have a little curve with a point on the far right, where as the OEM has the standard "stepped" design with the little angles in the center.
Overall, yours looks really good. Now hopefully people will stick with HID's in the headlights and avoid the fog lights.
Does the ES have the leveling system?
Just for comparison, here is the OEM HID output:
Such great knowledge and information specific to the Outlander Sport. Thanks for sharing as always!
When we first bought the car and I found the leveling system, I was thinking, I'm never going to use this thing? Until one day I hauled a cubic yard of rock for our garden out front which was about +1000 pounds I found the leveling system helped not blind the oncoming traffic as I was trying to land planes nearby with the HID's before I adjusted them.
Old Jul 10, 2013 | 09:38 AM
  #122
Burtonrider1002's Avatar
EvoM Moderator
I've noticed that as time has gone by my rear suspension has started to sag a little (well, ok, a lot) even though I have NEVER loaded much cargo in the back, and only trailered my waverunner a few times (tongue weight is like 100lbs at best). Over time I've had to aim mine further down to keep from blinding traffic as well.
Old Jul 10, 2013 | 12:06 PM
  #123
mRVRsport's Avatar
From: Out towards the countryside of Dallas, TX (USA)
Yeah, well it may not be the tailered (or cargo) weight that's the problem... Perhaps we should ask Who's been setting in the back seats, aye??
Old Jul 10, 2013 | 02:26 PM
  #124
EvoM Moderator
Yes, very true! Perhaps it is the groups of many beautiful young women at a time who frequent my back seat...
Or it's my backpack, laptop, and basic road-side kit... Depends on if I'm dreaming or not.
It's the latter.
Old Jul 10, 2013 | 02:43 PM
  #125
mRVRsport's Avatar
Got harem?
Old Jul 16, 2013 | 12:44 AM
  #126
EvoM Moderator
Originally Posted by Wesley Eng
Okay, stopped by a dark wall on the way home, got a few shots and a video showing the DDM HIDs in the stock halo projector along with my A/V setup.
I'm not sure how it compares to the factory HIDs, but I am really stoked about having real HID cutoffs! This is my first car with stock projectors!
Curiosity got the best of me, so I posted up your output shots on a lighting forum I'm on with your setup info. I left it anonymous, but if you'd like it gone just let me know.
http://www.hidplanet.com/forums/show...s-(Output-Pics)
Old Jul 16, 2013 | 01:01 AM
  #127
RA012124's Avatar
You forgot the youtube video!
Old Jul 16, 2013 | 03:01 AM
  #128
EvoM Moderator
I didn't post it because the first half was all about the A/V stuff.
Old Jul 19, 2013 | 07:44 PM
  #129
RA012124's Avatar
3 hours and 10 sore fingertips later...
It was a pain in the *** this time, because I had to run the 1/2" air line from the trunk, all the way to the engine bay and secure it real good so nothing rubs. Every time I'm under a vehicle, episodes of "100 ways to die" run through my head. I also forgot to add a switch to switch it between train horns and regular horns, but I ran out of daylight. I'll get some better pics tomorrow when the sun is back.
Attached Thumbnails Project Blackout-1078655_10200123849523331_526380769_o.jpg   Project Blackout-1075539_10200123849763337_464764589_o.jpg   Project Blackout-1072325_10200123850043344_266860175_o.jpg   Project Blackout-1074332_10200123850283350_803535394_o.jpg   Project Blackout-1077317_10200123850843364_1620440225_o.jpg
Old Jul 19, 2013 | 07:50 PM
  #130
mRVRsport's Avatar
Great job.
Looking forward to hearing the video.
PS:
Those zipties will weaken and get brittle from the heat over the exhaust manifold. Just a heads up.
Plus the fiberboard insulation may rip from the vibration stress of the horns' weight after an extended period of time.
Old Jul 19, 2013 | 08:09 PM
  #131
RA012124's Avatar
Great job.
PS:
Each horn weighs a few ounces. They're Plastic and these zipties are rated up to 180F. They're industrial strength zipties from my dad's job. He works on the railroads. The only thing I see failing is the insulation, because I don't know how strong the grommets are. I fished the zipties right next to the grommets to put less stress on the insulation even though the horns weigh like nothing. I really couldn't find any other way to mount these horns in there other than fabricating my own sheet metal.
The 1/2" air line I ran along with these 4 black rubber hoses that runs underneath the vehicle held up with this plastic white bracket. I ziptied the airline to those hoses/bracket so nothing sags. The airtank has Velcro underneath it's base plates which sticks to the cargo floor cover so I can move it around if I never have to. Not sure how secure it will be on hard left turns though. Might have to strap it to the luggage hook just in case so it doesn't tip over. The yellow coil hose coming out of the air tank is a tire chuck.
Old Jul 20, 2013 | 06:58 AM
  #132
XSTeknique's Avatar
Nicely done, but I sure hope the benefits of that massive horn outweigh the loss of trunk space.
Old Jul 20, 2013 | 07:02 AM
  #133
EvoM Moderator
How hard will it be to get your spare out now? Not my thing, but the install looks nice. I agree with mRVRsport about the zip ties though.
Old Jul 20, 2013 | 10:41 AM
  #134
RA012124's Avatar
I can fold my seat down and shift the tank over off the cargo floor cover. I'll take some pictures later.
By the time I had time to make a video, it started raining, but I did get to install a simple switch today. Kind of half ***'d the blank button thing and scuffed it all up.
The switch simply cuts into the solenoid circuit. Completing or disconnecting the circuit thus allowing the air to pass through to the horns or not.
Attached Thumbnails Project Blackout-1073838_10200127381131619_1429983859_o.jpg   Project Blackout-1072062_10200127380851612_1702356551_o.jpg   Project Blackout-1074514_10200127381371625_102751387_o.jpg   Project Blackout-1073185_10200127381691633_1833439666_o.jpg   Project Blackout-774384_10200127381931639_104818362_o.jpg
Old Jul 20, 2013 | 06:45 PM
  #135
TEXAS TRAVISTY's Avatar
that's crazy!
