My Newest Purchase: Takeda Short Ram Intake
#31
Good, because if it was then you bought the wrong car.
Regarding the engine remapping the car itself will adapt. Once you get it installed you should let the car idle for a while, which allows the Mass Air Flow (MAF) sensor to accurately analyze the new airflow, and the ECU/ECM (whatever it's called) will tweak the air/fuel ratios, timing, variable valve settings, or whatever it does normally.
Swapping the intake is no different than drastic changes in elevation. The MAF senses a change in air flow or density and responds according.
Thanks guys, I mean it. Between the group of you, your a endless fountain of Outlander knowledge. Newbish as they (my questions) may be, I appreciate the insight and knowledge.
#32
#35
I'm new to the forum and wanted to share that I installed my Takeda Air Intake yesterday on my 2012 OS. Thanks OP for the heads up on accessing the intake tubing on the TB. I ended up temporarily removing the OEM snorkel and used a drive palm ratchet with an extension to reach. The CVT struggle is now tolerable and feels more responsive taking off. I also installed an OEM Evo X front strut bar. I noticed a drastic improvement in steering, especially on highway ramps. Very little body lean and understeer! All in all, the upgrades are definitely worthwhile.
The following 2 users liked this post by DailyNews:
Burtonrider1002 (Apr 6, 2016),
NJ9MR (Apr 6, 2016)
#37
Newark, NJ. I'm taking my OS on a 400 mile round trip to Massachusetts and Albany today. Should be a good test for my new parts, mpg and performance wise. My Lexia diagbox came the other day, but didn't have a chance to play with the software as of yet.
#38
I might be a little late to the party here, but I have one of these. My 2014 has a different Mass Airflow Sensor mount, mine's a diamond shape. I made it fit, but I'm going to be looking to see if the 12-13 one is compatible with mine. Be warned, if you have a 2014....that little sensor mounting bracket is going to be your headache...and no one ever seems to know about it when you call to ask.
#40
I usually have my music pretty loud so I don't hear much engine noise.
#41
Maf sensor
CanuckLancer
Outlander Sport
16
Feb 12, 2020 10:42 AM
[FS] Double Din Kit
GSX_TO_EVO
Sep 13, 2016 06:40 AM
