14 OS Battery Terminal Disintegrated
Old Oct 27, 2017 | 10:42 AM
Hotpocket's Avatar
My positive battery terminal and attached fuses completely eroded. Anyone else run into this? Car only has 37k miles and all oil changes/maintenance were done on time at dealer. Dealer told me to pound sand.
Top of pic are what’s left of the positive terminal and fuses. Bottom are my replacement parts I purchased.
Old Oct 27, 2017 | 08:47 PM
mRVRsport's Avatar
From: Out towards the countryside of Dallas, TX (USA)
Now that's a first..
So the dealer is saying the corrosion destroyed the plastic too?
Looks more like the circuit/fuses blew and took the top portion of the plastic with it.
PS: so do you live near the Gulf? There does seem like quite abit of corrosion on the original post mount...
Old Oct 30, 2017 | 06:22 AM
Hotpocket's Avatar
The fuse had to be destroyed to remove it. The bolts were welded to it because of the corrosion. This time around I got the felt anti-corrosion pads and spray. I live in western Texas where there is rarely any humidity.
Old Oct 30, 2017 | 11:43 AM
mRVRsport's Avatar
I see..
Well, I'd would suggest you get a small 1oz tube of a copper based anti seize paste to use on the terminals/bolts, something like this >
instead of those silly felt pads. I've used them back in the 80's and they don't work!, waste of money.
Old Oct 30, 2017 | 02:50 PM
4b11slayer's Avatar
Your battery is probably seaping acid
bolsen
Jun 15, 2006 09:02 AM
sasquatch
May 15, 2006 03:24 PM
tke_413
Sep 16, 2005 05:03 AM
WindsorLancer
Jan 21, 2004 10:00 AM
