Red Cap on (+) Battery Terminal
Old Jan 20, 2004 | 10:40 AM
WindsorLancer's Avatar
Question Red Cap on (+) Battery Terminal
I had to give someone at work a jump start the other night because it was -29 C when I came out of work and when I tried to lift the clip that holds the cap on the (+) battery terminal the whole cap snapped in half because of the cold. Is it important that it be there? I noticed there is more that just a wire and a clamp attached (like on the (-) side, which was what the cap seemed to be covering. I'm probably being paranoid but I just need to know if I should go get a new one or just leave it for now.
Old Jan 20, 2004 | 10:42 AM
Recon's Avatar
i think its just a cover i dont have mine on anymore
Old Jan 20, 2004 | 10:45 AM
ok, I won't worry about it then...
Old Jan 20, 2004 | 10:47 AM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
It's just a cover, it keeps all those wires from touching metal and shorting something out. You could wrap the cluster of connections with electrical tape just to make sure, but it's probably pretty stable where it is on the battery. I had to wrap it in electrical tape because when I moved the battery it left that whole cluster exposed and dangling around in the engine bay.
Old Jan 20, 2004 | 12:02 PM
I wonder how much a dealer would rip me off for a new one??
Old Jan 20, 2004 | 12:09 PM
Drive02Lancer's Avatar
heh i cut a slot in mine so i could run 2 power wires(speaker wire) inside to my neons
Old Jan 20, 2004 | 04:42 PM
sdhotwn's Avatar
The purpose is to prevent shorts that can lead to a fire. Since the terminal itself is not fused there is nothing to limit current and it could theoretically make your battery explode from the heat and the like..
You can just cover it completely with any non-conductive rubber, or just cover it in electrical tape.
Old Jan 21, 2004 | 09:55 AM
Well, I won't have to worry too much about excessive heat around here for a while, even with the engine running.. It won't be getting near 0 C for a couple weeks.
Old Jan 21, 2004 | 09:57 AM
Actually, looking at it now, it only broke in 2 pieces, I think I might be able to tape it together and somehow secure it on...
Old Jan 21, 2004 | 10:00 AM
Anyone willing to sell thiers?
Cody Parrott
Lancer Troubleshooting
Jul 10, 2024 08:41 AM
newblancer
Lancer Engine Tech
Jul 1, 2016 09:35 PM
kyoo
10
Jan 26, 2016 03:02 PM
Ralli04
Sep 6, 2008 10:03 PM
amscrazy
Jan 30, 2008 11:33 AM
