Outlander 3 Dashboard
Old Nov 6, 2022 | 04:54 AM
鱼鱼's Avatar
Can you realize the interface of tire pressure value and temperature on the Outlander dashboard? Not just one warning light!
Old Nov 6, 2022 | 05:50 AM
Hello / Welcome
Any chance you can translate your question into English, please
Cheers,
Old Nov 6, 2022 | 06:39 AM
鱼鱼's Avatar
Old Nov 8, 2022 | 02:40 AM
Landshark's Avatar
i used these when i had my Evo, and will be using them in my wife's OS when i use it for winter duty and put a set of snow tires on it that don't have TPMS sensors.
the display plugs in to the 12V cig lighter port.
Amazon Amazon
Old Nov 8, 2022 | 03:14 AM
鱼鱼's Avatar
No, no, you misunderstood. I mean how the signal of the tire pressure sensor of the original car is realized on the instrument! It's not an external screen.
Old Nov 9, 2022 | 11:04 AM
CDrinkH2O's Avatar
欢迎 鱼鱼!
The original car has TPMS sensors inside each wheel. The sensors communicate using a wireless (radio frequency) connection with the instrument. If you remove the tires you can see the sensors. If you change the wheels you need a special tool to make the ECU relearn the sensors. On YouTube, there is a video of the TPMS relearn procedure
原车的每个车轮内部都有 TPMS 传感器。 传感器使用无线(射频)连接与仪器进行通信。 如果您卸下轮胎,您可以看到传感器。 如果您更换车轮,您需要一个特殊工具来让 ECU 重新学习传感器。 YouTube 上有一段 TPMS 重新学习过程的视频
Old Nov 10, 2022 | 08:27 AM
Dustball's Avatar
All, the OP is looking to have the dash display the actual pressure and temperature values from the TPMS sensors. This cannot be done- needs an external display from an aftermarket manufacturer.
Old Nov 13, 2022 | 03:52 AM
鱼鱼's Avatar
If the tire pressure program is written into the original vehicle instrument? Will it come true?
RA012124
Outlander Sport
35
Nov 26, 2013 12:37 AM
RA012124
Outlander Sport
Jun 8, 2013 06:15 AM
catherineapop
Outlander Sport
16
Jan 23, 2013 06:52 AM
x2003lancerESx
Jul 17, 2012 04:05 PM
