Pacific Northwest General areas surrounding Bellingham, Seattle, Tacoma, Bellevue, Spokane, Yakima, Portland, Eugene, Bend, Medford
Portland E85 and injector tip gunk
Old Jan 1, 2012 | 08:15 PM
  #31
ILoveAWD's Avatar
Originally Posted by mrfred
There's no evidence on Evos of rubber fuel lines being eaten away by ethanol. razorlab did a complete teardown of his fuel system after several years of running E85, and everything was prestine. In addition, I had zero problems with gunk buildup when I was in the Tri-Cities.
well that is good to know, that means i shouldnt have to replace all my line lol. but i was just sharing what i herd and know!
Old Jan 1, 2012 | 08:49 PM
  #32
R/TErnie's Avatar
Mine had some build up on them. I get mine exclusively from Marysville (exit 206) and I store it at my house in 55 gallon drums.
I went back to pump gas and ran a tank through...seemed to clean them up nicely.
Old Jan 1, 2012 | 09:26 PM
  #33
mrfred's Avatar
Also, there's only about 2.5 feet total of rubber fuel line in the Evo fuel system.
I ordered up some of the fuel system cleaner, but I suppose running a tank of premium is the more convenient option.
Old Jan 2, 2012 | 08:11 AM
  #34
keath's Avatar
Originally Posted by 4thStroke
When I first got Aarons 2150s, they worked flawlessly. In fact, the night they wrecked me, they did just fine for a few pulls. It seemed out of nowhere the buildup got the best of me. If the inector completely shut off, that would have been fine, I would have been on 3 cylinders (hurah for the Subie rumble!) and it would have been a matter of cleaning the injectors.
Cylinder 4 went wayyyyyy lean (kept spraying fuel, but not enough to keep the AFR rish enough and the EGTs cool) and melted a large hole in my head and put a couple divots in my block while destroying the head gasket. Luckily, my head and block are salvageable, but by no means was a it cheap and easy fix.
Keep an eye on your injectors, guys.
ok last night I did some pulls and i heard a pop and it started to sound like a subbie rumble. from 1k rpm to 2.5 rpm.
stumbled home and took apart the injectors and one of them were just clogged with gunk..
cleaned them off and started the car again and the rumble is still there.
changed back to pump gas and pump map and the rumble does not go away.
i have precision 1200 injectors and they all read 2.4 ohms.
could i have damaged the head? how else can i check the injectors?
i will try to post vid on the noise.
please help guys
Old Jan 2, 2012 | 11:35 AM
  #35
TurboTim06's Avatar
Yes post a vid so we can hear it...are u saying it idles rough but goed away with rpm? did u check all vac. lines and IC Pipe's?...engine light? Do u kno what your AFR's looked like at the time this issue happened? Hows it run above 2.5k rpm?
Lines?
please help guys
Old Sep 7, 2016 | 03:21 PM
  #36
mrfred's Avatar
I have an update in the E85 injector gunk thread:
https://www.evolutionm.net/forums/e8...l#post11661335
logic
E85 / Ethanol
315
Apr 24, 2020 11:58 AM
gymnasty
E85 / Ethanol
162
May 7, 2018 03:52 PM
42revoincali
For Sale - Miscellaneous Automotive
May 18, 2016 10:46 AM
FlashEvolution
Mar 21, 2016 06:50 PM
Kris Pomilla
Mar 2, 2016 04:43 PM
