Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
TPMS - the ultimate FAQ
Old Mar 3, 2014, 12:47 AM
  #121
ddoherty64's Avatar
my valve stem broke!
I went to fill my tires with air, and the valve stem broke off and deflated 2 of my tires and I replaced them with rubber stems for now. how much would I be looking to spend to get them replaced?
Old May 12, 2014, 01:38 PM
  #122
Newuser213's Avatar
I got a 2012 ES with stock wheels(hub caps) and I'm thinking of getting the 2008-2011 GTS 18" rims and new tires on it. Do I just put the TPMS from my ES wheel onto the GTS wheels? Would I need it to be programmed? Also would I need new lug nuts? What kind? where do I get them? Price?
Old May 13, 2014, 09:47 AM
  #123
Veronica's Avatar
Good news!
Any tire shop can repair the sensor (so you won't have to pay to re-synch a new one)...
Kit costs $14
Install was ~$20 at my tire shop
VERSUS
TPMS+ synch installed at dealership was > $130
Kit is: http://www.ebay.com/itm/20725-Tire-P...r#ht_500wt_916
Old May 13, 2014, 04:06 PM
  #124
Badhazard's Avatar
Do I just put the TPMS from my ES wheel onto the GTS wheels? Yes.
Would I need it to be programmed? No, because those are your "stock" sensors and it's already programmed to the car. If you bought new sensors or came from a different car, you would need to reprogram it.
Also would I need new lug nuts? Yes and no, it's a tricky question. Based on what you have said. I would say "no, you do not need new lugs". Reason being, Mitsubishi like to use "mag" style lug nuts. (Google it). Since you're using a Mitsubishi OEM wheel, most likely it is a mag style lug.
What kind? Depending on the wheel. Most likely mag style.
where do I get them? O Riley's, advanced, autozone, dealer
Price? Varies. Mag style isn't cheap.
Old May 14, 2014, 10:17 AM
  #125
Newuser213's Avatar
Thanks!
Old Oct 11, 2014, 04:25 PM
  #126
greenfire's Avatar
Anyone figure out how to re-program the sensors yourself? Is there a scanner tool we can buy?
$40 every spring and fall.. when changing out snow tires is a bit much. Not to mention the hassle of going to the dealer.
There has to be a way.
Edit: Ok I found this.... anyone try it?
Amazon.com: ATEQ Mitsubishi Lancer Outlander Mirage Tire Pressure Monitoring System TPMS Reset Tool: Automotive Amazon.com: ATEQ Mitsubishi Lancer Outlander Mirage Tire Pressure Monitoring System TPMS Reset Tool: Automotive
Old Oct 13, 2014, 11:33 AM
  #127
TPMS N.G.S.'s Avatar
I can program sensors for you.
As for the ATEQ
It looks like you need a reader or some sort of diagnostic tool to trigger the units as per the instructions on Amazon:
Operation:
1. Connect MitsuReset tool to the OBDII connector of the vehicle. Turn ignition on.
2. Press the MitsuReset "ON" button.
3. Use TPMS diagnostic tool to trigger TPM sensors.
4. After triggering all TPMS sensors on the vehicle, the green light on MitsuReset tool will turn solid indicating successful loading of the new TPMS ID's. Turn ignition off and disconnect the device from the vehicle. The TPMS light of the vehicle will turn off.
Old Oct 13, 2014, 04:43 PM
  #128
greenfire's Avatar
As for the ATEQ
Operation:
Yes, quite an investment now. Wish I has seen your setup earlier.
Old Feb 15, 2015, 09:57 AM
  #129
Joel_valle's Avatar
Im planning on transfering my tpms tomorow, thanx for the input!!!
Old Mar 23, 2015, 04:56 AM
  #130
In case anyone needs help with the TPMS-
https://www.evolutionm.net/forums/ve...your-dash.html
Old May 14, 2021, 10:38 PM
  #131
OctaneTENgsr's Avatar
Tpms
Don't know if its been mentioned yet, but i know that after a certain period of time with the battery disconnected, the system will lose its assignment with the sensors and trigger a TPMS service required light. The low tire detection will still function, but it will always show the TPMS service light. I believe it takes about 14 days.
I have TE37sl's with sensors installed and assigned. The system was operating normally. I had the car apart to do a clutch, and the neg terminal was off the batt. for aprox 30days. Upon finishing the job, the TPMS service light appeared.
Afterwards, I got a low psi warning. I checked and had a low tire. After i filled it, the low psi light went out, but the TPMS service light remains on. I was also one of the lucky few to have the valve stem corrode and snap off while airing up a tire. What a joy that was.
Gotta love how mitsubishi designed the TPMS. Basically, its completely unserviceable by the ordinary owner, you get no indication of which tire(s) are effected when a fault is triggered, and its difficult to know if theres an actual low tire or a system fault.
Why couldn't they design it to work like Toyota? They just stick a button under the dash or in the glove box, allowing you to reset the system or force a relearn.
I hate TPMS anyway. Low tires have the ability to be checked with a gauge. PPL managed to operate vehicles close to a century without TPMS and the world continued to turn. If you need a warning light telling you the tires need air, maybe you should re-evaluate your ability to operate a vehicle.
Old May 14, 2021, 10:42 PM
  #132
Anyone who relies on a dash light to know when their tires need air should sell their car and start taking the bus.
All cars should have the option to disable TPMS
Moss507 (May 15, 2021)
Old May 15, 2021, 08:48 AM
  #133
Biggiesacks's Avatar
I get that it's a hassle to deal with, but the TPMS is a really nice safety feature. I picked up a nail on a road trip with my X and the TPMS gave me enough early warning to get off the road, inspect / fill the tire and take it to a tire place and have it patched. Without the TPMS it's likely I would have ended up on the side of the highway swapping on the spare, putting my family at risk and probably replacing the tire instead of having it repaired. The worst case could have been a blowout at highway speed.
packrat
149
Apr 28, 2018 07:59 PM
Farga
Pacific Northwest
11
Jun 10, 2012 11:37 AM
R Lar
21
Jul 26, 2011 04:48 PM
laksman91
Feb 23, 2009 08:07 AM
BlaqueGhost
Canadian Forum
27
Apr 5, 2008 03:08 PM
Quick Reply: TPMS - the ultimate FAQ
