I look forward to getting mine tomorrow morning at Cobb Plano
Will COBB AP benefit my setup?
Relatively speaking, I'm somewhat new to the Mitsubishi scene. I have a very good background with Honda/Acura stuff, and can build bottom ends, do minor tuning w/ Hondata, etc.
I guess you could say this question is for the advanced people on this board... First, here is my setup: 2008 EVO X GSR AMS UICP, intake, test-pipe, cat-back exhaust I baselined the car on a Mustang 500 SE before installting the mentioned parts. The car put down 215whp, 257wtq. After adding the bolton mods, I re-dyno'd, same day, and made 282whp, 302wtq. Obviously, my car was leaned out automatically by the combination in mods that I installed. I went from just above 10.0:1 to around 11.8:1 through most of the powerband, and I also picked up a pound or so of boost... but here's my question: In my opinion, the big gains in the EVO X market have either come from the addition of bolton parts (like mine) that artificially lean the car out... OR, you install something like an AccessPort to lean the car out and pick up good gains. WHAT IF you do both? Meaning... For $695, should I expect little to no gains over the stock tune since I've already "cashed in" on my +67whp gains from the bolton parts? I'm currently waiting on AMS to release their o2/downpipe. After that is installed, I planned to add the AccessPort to pickup anything else remaining on the plate. What do you guys think? What have you seen? Decent gains even WITH boltons on the car? Any inputs appreciated. FWIW, we have 93 octane here in Connecticut, so I'd imagine I can pick up a few ponies with a degree or two of timing. Thanks guys! - Louis |
I have similar mods, but a high flow cat instead of the test pipe and I still have the stock UICP. I have a turbo back exhaust including the o2 housing.
Here's what a custom stage 2 AccessPort dyno tuning netted me (interesting that you have almost EXACTLY the same no-tune dyno numbers that I had): http://mpghead.com/evo/dyno_tune.jpg So 21hp and 37ftlb tq. |
Originally Posted by HybridKOOP
(Post 6748016)
I guess you could say this question is for the advanced people on this board... First, here is my setup: 2008 EVO X GSR AMS UICP, intake, test-pipe, cat-back exhaust I baselined the car on a Mustang 500 SE before installting the mentioned parts. The car put down 215whp, 257wtq. After adding the bolton mods, I re-dyno'd, same day, and made 282whp, 302wtq. Obviously, my car was leaned out automatically by the combination in mods that I installed. I went from just above 10.0:1 to around 11.8:1 through most of the powerband, and I also picked up a pound or so of boost... but here's my question: In my opinion, the big gains in the EVO X market have either come from the addition of bolton parts (like mine) that artificially lean the car out... OR, you install something like an AccessPort to lean the car out and pick up good gains. WHAT IF you do both? Meaning... For $695, should I expect little to no gains over the stock tune since I've already "cashed in" on my +67whp gains from the bolton parts? I'm currently waiting on AMS to release their o2/downpipe. After that is installed, I planned to add the AccessPort to pickup anything else remaining on the plate. What do you guys think? What have you seen? Decent gains even WITH boltons on the car? Any inputs appreciated. FWIW, we have 93 octane here in Connecticut, so I'd imagine I can pick up a few ponies with a degree or two of timing. Thanks guys! - Louis You will definitely pick up some power as well as smooth out the power band and over all drive-ability. What intake are you running? To be quite honest your AFRs are a bit on the lean side. Thanks, |
Wow, what a great comparison! It looks like our baselines were within 5whp of eachother! Can't ever go wrong with Mustang Dynos...
Here's my stock vs. bolt-on runs: http://www.hybridkoop.com/images/lou_evo10.jpg - Louis {thumbup} |
Louis, resize that image...it's ginormous!
Originally Posted by goofygrin
(Post 6748101)
Good question! I will be running a similiar setup come summertime and wanted to know how well AP would benefit my boltons as well. {thumbup}
*subscribed* |
mods are in my sig, i netted about 40whp with a custom tune, i forget how much tq. but i hope to pump out some more hp when i get my injectors and fuelpump installed. i'm pretty sure with a custom tune you will for sure gain a lot more power!
interesting...I'll be getting my car tuned next week with Cobb in Plano. I'll have the following mods for reference.
T1R tbe incl o2 housing dp and test pipe T1R uicp and licp AGP fmic Works drop in filter tuned with Accessport I'm curious as to what it'll yield with a custom tune. never baselined the car so I won't know what the actual gain will be. however, I'll just estimate with what people are putting down on an average stock x. |
Originally Posted by CmakEVOX
(Post 6741814)
I am pretty much sold in getting the Cobb AP. I hear lots of good things about it and started a savings fund/jar already.
My question is, can the Cobb AP be bad for newbies to engine tuning/flashing? Can the Cobb AP do major damage to the car if not used properly? Sorry for the newb question, but i just wanted to see what the cons are since there are so many pros. |
(Post 6741814)
My question is, can the Cobb AP be bad for newbies to engine tuning/flashing? Can the Cobb AP do major damage to the car if not used properly? Sorry for the newb question, but i just wanted to see what the cons are since there are so many pros. do it imo that is the best choice you could make. No worries about not using it properly you really can't screw it up.....well maybe you can but you woul dhave to try really hard. Very easy install, and with the current updates it takes a total of maybe 3 mins to transform your mild manner X into a beast. |
Nice review. I wonder if I should just get this or try ecuflash or ecutek.
Originally Posted by Excalibur
(Post 6753912)
Hows that update coming along?
